Topic: Free 3.8 - must pick up (Read 1181 times) previous topic - next topic
anyone need any 3.8 parts (1986) ? the engine ran when parked, i put a batt in the car and the engine turns and sounds fine. i didn't start it, the plug wires are wasted.
anyway post what you need, it's a complete engine with all the brackets,etc.
*EDIT*  i will give the engine/trans to whoever wants it but you MUST pick it up.  if someone wants it let me know and i'll get it pulled out.
86 thunderbird elan
86 mustang coupe
wish you were closer, because i need everything... mine's running like ... are you doing a swap?
Quote from: mywifeskitty;284840
eventually, but i want to get the 6 out. tell you what, i'll GIVE you the engine when it's out, just have to give me a little time and you have to pick it up. i didn't start it, squirrels chewed some of the plug wires. it sounds fine when you crank it, no noises or anything. i was told the trans slips and that's why it was parked. you can have that also if you want it.
86 thunderbird elan
86 mustang coupe
thats a hell of a deal. You better go c00ch that up. A free motor and tranny is definately worth the drive, even if its across the state, lol.
How many miles are on it? I could maybe use a new air pump if it's the right one.
Heck, that's only about a 15 hour drive from here, not including stops. If gas stays under $2.50, that'd be like a hundred bucks... Totally worth it!
Happy Motoring! :burnout:
Quote from: jrad235;284890
wow i'm a little late on this one, sorry. the odo reads 120k or so
86 thunderbird elan
86 mustang coupe
