Topic: Vibration issue.... (Read 4288 times) previous topic - next topic
Vibration issue....
When the Sport gets to about 75mph,there's a vibration then,after about 80,it seems to mostly go away,but,if I let off the gas at those speeds,there's more of a vibration.Any ideas? Axle bearings maybe?
Vibration issue....
Didn't you just get new wheels? Is it possible a weight fell off?
Vibration issue....
I'd vote wheel balancing or u-joint.
1979 Ford Fairmont
[/B]
Vibration issue....
I vote U-joint, if it was there last week with the old wheels
Vibration issue....
I just swapped the u-joints,and the vibration was a little worse consistently after 75 before the u-joints.Even with the other wheels.
Vibration issue....
Thats the rumble of the V8.  You'll get used to it after a while.
Vibration issue....
where does if feel like it's coming from?
front or back?
Vibration issue....
Back.I had the driveshaft balanced a while back,now it has new tires and wheels (that feel very smooth on the highway),and new u-joints.
Vibration issue....
I guess were heading towards the rear end now
Vibration issue....
bolts tight on the driveshaft?
Vibration issue....
Tight as they can be.
Vibration issue....
have you tried unbolting the d-shaft and rotating it and rebolting it?
Mabe it's out of balance with the rear end there
Vibration issue....
I'll try that and let you know what happens.
Vibration issue....
Is the drive shaft out of round/bent?
Vibration issue....
I just had it balanced.
