Topic: Vibration issue.... (Read 4287 times) previous topic - next topic
Vibration issue....
There was no run out on the shaft?
Vibration issue....
stick a large hose clamp on the driveshaft and see if you can counter the vibrating by changing the position in 45 to 90 degree incremints. If it only gets worse, and doesn't get better, then it probably isn't in the drive shaft. I have had alot of bad luck with wheels and tires being balanced correctly, as well as the front suspension having alot of slack in it.
Vibration issue....
My Mustang did this and one of the axles were bent. 100% stock rear and drivetrain in the car with about 65,000 miles on it.
Vibration issue....
Quote from: Haystack;280526
exactly.
or, your out of phase like Dr D said.
being out of phase on a two piece d/s is more common such as in the 4wd world.  With our one piece d/s, If you installed one of your ends on the opposite way, then it nulls out your whole "I had it balanced" theory.  Mark that shiznit before you take it apart. That would make it out of "phase",, kinda but not exactly.
Vibration issue....
Marking it didn't really seem appropriate when it was removed (the driveshaft) because the drive shaft,tranny,engine,differential,and pretty much every part of the car came from different vehicles.
As far as a bent axle,I'd think if the axle was bent,wouldn't give me trouble before 75 MPH?,and also,after swapping the u-joints,the vibration still comes up at 75 or so,but then goes away after 80.I need it gone completely.I'm buying new bearings and seals today after work and installing them this weekend (weather permitting) and see what happens.
Vibration issue....
I get where your coming from on the "everything came from a diff car"
But try flipping the u-joint around on the rear. mabe try another (not sure what that piece is called that bolts the u-joint to the rear) LOL
Maybe you got a bad bushing or loose bolt on a rear arm(s) transferring vibration?
Vibration issue....
Some have said it is possible for the input shaft of the tranny to do that vibration thing.
Unsure how to diagnose that, Im really helpful.
Mike
Vibration issue....
It did it with the aod to didn't it? while you got it apart check the pinion bearing for excessive play.
Vibration issue....
What is the frequency of the vibration?  Is it a higher or lower frequency?  Can you feel it in the steering wheel?
I've solved a couple of vibration problems by removing the wheels and cleaning the mating surface from the brake to the wheel.
Vibration issue....
To me, it sounds (seems) like a tire issue. Is it possible one of your new tires has a knot?
I had a knotted tire one time, it would only vibrate right at 65 mph...
Spent an hour changing a rotor and bearings/seals, only to notice a slight knot in the  tire as I was putting the wheel and tire back on...
1 new tire later, I was ridin' smooth again...
I'd think with brand new tires, it's quite unlikely...but anything's possible.
If the problem wasn't there before, and the only thing changed is the wheels and tires...;)
I'm hopin it's not something expensive though Vman.
Vibration issue....
Can't feel it in thwe wheel.I'm going to invest a little time this Sunday.I've been back and forth to my grandmother's a lot lately.
Vibration issue....
Use the big hose clamp. Did it do it before your new wheels? Are you sure that the wheels are balanced? I hate the front suspensions on these cars. Every vibration I have ever had was one of these two things, or loose/stripped lug nuts.
Vibration issue....
Everything in the front has been replaced.It did vibrate around 75 and up for quite a while.After I swapped the u-joints,less vibration AFTER 80,but still around 75 or so.I feel it in the shifter handle and the floor,not the steering wheel or pedals.
Vibration issue....
I bet the part that bolts the u-joint to the rear is out of whack
