Topic: new radiator research (Read 4716 times) previous topic - next topic
hey guys i need a little radiator advice i need to change mine and i tought id go with something thats may cool and dissipate the heat a little better than the copper/brass one  now i dont want to pay a 400$ one my budget would be in the 200 ish  and all i seem to find is this
http://www.summitracing.com/parts/PLI-433556/?image=large
what do you guys think its made from aluminum but only has one row  how should it do
all comments and suggestions are welcome!!
also i had tought maybe a mustang rad from latemodelresto could do it
ps  i have an 86 3.8 bird
thanx!!
For the price it would probably work. I like how they mention modine style. not a modine just styled like it. If your staying all stock it should be ok.
Brass/Copper is a better conductor for heat than aluminum, however aluminum is lighter.
Most aluminum aftermarket pieces are one row(some are two), but generally have bigger tubes to help them cool better and overcome the inherent differences in cooling ability vs brass/copper.
FWIW -- you can purchase a brass/copper replacement 3-core radiator made by Visteon (the OEM supplier for Fox body radiators) for under $200.  I paid $160ish for mine.  Works VERY well.  I picked mine up from Pep Boys.
I see they have an aluminum one row on there for like $140.  I would assume it would do the job on your application, but I personally am not a fan of plastic side tanks....
Quote from: V8Demon;278323
absolutely right, not many really consider how large the cooling channels are when buying a new radiator. however, ill stick with the brass/copper rads for reliability and durability purposes.
it doesnt take a very large rock to make your new aluminum radiator useless:punchballs:
this is the one that I bought and put in mine.its a little more than you want to spend,but a nice radiator
http://www.summitracing.com/parts/SUM-380451/
the v6 and v8 OE part #'s are the same.I originally had the 3.8 but now have a 302.you will have to do very little modification to the rad. hold down brackets but they do work just fine.
you will also need to buy an adapter kit for the trans. cooling lines.they are a diff. size on the new radiator.
Quote from: Ductape91;278324
Like I said -- mine's brass ;)
theres a guy that claims he had a garage and is having a blowout sale
he has a 2 row copper /brass for 75$ the brand is autokool but i wonder if i should get a 3 row or 2 is enough
btw do you recal whats the part number on yours V8Demon?
I have a Napa/Modine replacement Rad in my car. It's a single core alum with plastic tanks and end tank trans cooler. It was about $130 and has been great with my V8.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
I can't remember it,but Rockauto has it listed as part #5563....
Price $287...
Quote from: 88BlueBird;278478
I bought a radiator (factory style replacement) a few years ago,and it got a hole in it.I have the lifetime warranty,and they (Aytozone)gave me the same kind as 88Bluebird,aluminum with plastic tanks as a replacement.It's been great,no worries,and the car stays really cool.Even in above 100 degree weather.
I don't trust AutoZone's radiators/heater cores.  I spent the time putting in one of their heater cores in my old bird and a week later it exploded...i tore it all apart, got a refund and bought a ford unit and never had another problem....I used to work for them and know what's junk and what is okay...I'm still a little jaded.
i know a lot of parts that are sold at Autozone are made by companies that supply O'Reillys,and others.It still works great in the Sport with zero issues.
I have the stock radiator (yeah the 21 year old one :hick:) with a  180* thermostat and a 5.0 Mustang police interceptor fan clutch. It cools my T-bird fine even in traffic when it's 95* and I have the A/C on. The temp gauge never gets past the half way point.
if you want the biggest radiator for your car-visteon, who
in the 80's was a ford  supplier has a 3 row all metal [no
plastic tanks] radiator, part # 138--24x 18 x1-9/16. my
cost on it is 215.00. list is 315.00. this is through my
supplier. i put one in my cougar even though there is
nothing wrong w/the original.looks factory just a little thicker.
--irv:D
