Topic: new radiator research (Read 4674 times) previous topic - next topic
Quote from: irv;278719
if you want the biggest radiator for your car-visteon, who
in the 80's was ford supplier has a 3 row all metal [no
plastic tanks] radiator, part # 138--24x 18 x1-9/16. my
cost on it is 215.00. list is 315.00. this is through my
supplier. i put one in my cougar even thuogh there is
nothing wrong w/the original.looks factory just a little thicker.
--irv:D
Irv, this is the same unit I speak of.  It's amazing how much they've gone up in price.  I only got mine less than 3 years ago.
i think i paid less than 150.00 last summer
my jobber is 1800 radiator. if you shop around
you might find it cheaper.--irv
I'm trying the aluminum 3 core from corral - should be here Monday. Besides more water weight, I'm hoping it will mean the electric fan being on much less. Stock Autozone replacement has worked fine for 3 years now but I still don't trust it.
Pretty much any radiator that fits should work fine on the car. There is little quality control now days so just about anything you can buy for a reasonable price will have a chance of going bad quickly. There's little you can do about this without spending $500+ or reinforcing the radiator yourself.
1988 Thunderbird Sport
they shop near my house can get his hands on spctra part no CU138 but i dont get it on their website they list the 556 as exactly the same specs anyone found a difference?
http://prod.spectra-ssl.com/PROD/apps/eCat/v1.07.01/mainfile.php?vehicle_id=1140208&model=THUNDERBIRD&year=1986&make=FORD&splash=false&action=search_by_vehicle&module=product_catalog&APP_VERS=1.07.01 heres the link  also he said it would cost 274$  and its a one row aluminium  this seems kinda pricey  im starting to consider the other guy with his 2 row brass copper rad for 75$
apparently i dont really need a 3 row some radiator shop told me as a 2 row would cool the 3.8 sufficiently  any opinions?
My 3 row won't fit with a trimmed Mark VIII fan so I picked up the lifetime warranty aluminum one from NAPA - single core but should work fine and give me plenty of clearance for whatever I want to install in the engine bay. People also seem to have better luck with plastic tanks than 100% aluminum - stress issues from chassis flex.
I used one for a 93 mustang because they said they don't carry anything for my thunderbird. Its a stock replacement 2 core, and haven't had a problem, minus the leaky heatercore hses.
It's amazing how companies don't know how to cross reference part #'s....
for my v6 cougar i used the brass/copper 3 row.the 3 row work better than the 2 row when i was stock.
I've got a two-row brass rad in the T-Bird, but it's as thick as a three-row. The tubes are about 50% wider than they were in the original rad, and the fins are denser. I've never had a problem with cooling my 5.0, even towing a 1500 lb trailer in the summer with the A/C on.
As for durability of aluminum rads: When I worked at the Saturn dealership I'd seen radiators that were wrapped around trees and didn't leak. In one case the guy's insurance company wasn't going to pay for a new rad because it didn't leak, but the guy growled enough that they relented. On the other hand, the plastic tanks don't age well. Saturns are known for the plastic tanks cracking with age, and I had to replace the rad in my Maxima because the top tank was cracked. 12 years old and the fins and tubes were perfect, but the plastic tanks were brittle.
On the subject of price: Everything made from copper or brass doubled in price last year when commodity prices were high. The prices have since crashed, but of course the manufacturers did not lower their prices...
1986 elan
which rad did you end up going with ? im on a search myself for my 3.8 1984 cougar.
just wondering what you ended up with? the one thats in now is starting to leak at the seam around the connection where the hose goes. a ford oem is listed at about $197
i assume that is made by visteon ? i was wondering too about cooling better as the 3.8 kinda has issues over the 5.0 as we know.
eddie
my rides well some of them work:hick:
1995 towncar in black 246 K non running
1989 continental 110K waiting for a part
1984 cougar head gaskets done almost ready!
Yikes the daily ride ...1998 chevy lumina:hick:
blackcat  heres what happened: a local guy on craiglist claimed he owned a garage before and had some leftovers that he was selling for 60$ if my memory is good  75$ max incase im wrong  so that was  the price  its a ordinary brass 2 core radiator  its even made it china... anyhow its doing the job doesnt overheat  and everyhting is fine
Seb
i found a visteon brand .... the posts above said that is the OEM brand. i found it on amazon for $136 no tax and free shipping. if  visteon makes it for ford then the same one from  a online dealer website is $197 then there is tax and shipping.
eddie
When I replaced my engine, I just replaced mine with the 1 core autozone rad with plastic tanks($100, and lif. warr.) and put an electric fan on it, 75% of the time my temp guage reads below C, and I freed up a couple horses. I'm happy.
If you over heat a aluminum rad. They do have a tendency  to expand,and litterly expand enough to close there passages up. I've been seeing more an more. Mostly with gm's, cause that's what I work on. Not sure about others.
