Topic: Stock '87 Power TC seats (Read 1622 times) previous topic - next topic
Anyone else who is tall have an issue with whacking their head on the roof everytime you hit a bump?
I'm 6'2 and every  time I hit a bump, my head whacks the roof.  It it honestly starting to be annoying to the point that I'd prefer to drive my 08 Impala as often as possible.  Nothing like driving to work and hitting a bump which makes you whack your head then you get a  headache.
I also hit the turn signal lever everytime I push in the clutch and I also cannot put down the steering wheel any because of my knees.
Anyhow...
As for the power seat buttons-everything works except the rear tilt and the power lumbar will only push out the lumbar, but not retract it.
The seat is all the way back, all the way down and the front tilt is all the way down.  The front part of the seat seems to be slanted up...is that from the rear tilt?
Any ideas?  Any suggestions from tall men who own a 87 TC......
I leave the front part of the seat all the way up, the rear all the way down, seat all the way back and the back part of the seat tilted back alittle ways. Probably couldn't even fit a bottle of anti freeze in the back seat. I would put the lumbar back in all the way. I just don't see how it could actually help any at all. I do not have a clutch, yet, and haven't had any problems with the turn signals or any of the levers.
Quote from: Haystack;276134
mine is pretty much set like your...I can't retract the lumbar; the button doesn't work when I try to retract it.  =(
First, no matter what happened with our T-Bird, it could never be bad enough to get me into an Impala. LOL. Regarding the seat not moving, I have seen many problems like that and it has always been a bad motor on the seat track assembly. We've got tons of them, so I have always just pulled the seat, swapped the power track assembly, pitched the old seat track assembly and motored happily along.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
Quote from: 85turbotbird;276133
Anyhow...
I'm 6'4" and have a similar complaint. My mom bought the Sport new in 88.  I thought it was the hottest ride short of a Mark VII and couldn't wait to put miles on it. It took a few times behind the wheel to turn me off of the car. Even with the seal all the way back, down and reclined it's tight. I hit everything while getting in & out. Now 21 years and 70 lbs later I decided to restore it. I recall a company that sold seat track relocators. They are supposed to give a few more inches of leg room. I suppose I could also get a second pair of knees installed.
1974 Falcon XB-GT Coupe
1988 Thunderbird Sport
1962 Thunderbird convertible
1971 Mustang Mach1 429SCJ
Quote from: Mr-Mach1;278971
yeah, it made me want to drive my '08 Impala more than drive the tbird, but since I've taken the arm rest off of the door panel, I've gained a TON of leg room..now I can position my foot on the clutch so I don't hit the turn signal everytime I have to push the clutch.
Here's a link to the seat relocator. For $70 I'm going to give it a try when the time comes as it promises 4.5" of additional leg room. I might try removing the arm rest as well. It a little is good, more is better.
http://www.mass-air.com/Products.htm#Seat%20Trax%20Xtenders!!
Quote from: Mr-Mach1;278975
my issue now is basically the head clearance..I still have to tilt my head if I know I'm going over a bump.
tbird232ci is going to try to fabricate some delete panels for the doors..stay tuned.
But our seat tracks are different than Stangs.
Quote from: vinnietbird;278986
In which way are they different ? I didnt think of that ? I just ASSumed they'd fit.
There farther apart and what not. If your just gonna buy a flat peice of steel, why not make your own and drill holes where you need it?. I'm still not sure how you guys are hitting your heads. maybe its because I slouch alittle bit. I don't think I have ever hit my head on the roof either. I get out almost like an old man crawling out of bed in the morning though.
darn! i was hoping that would work too. thats part of the
reason i want to get rid of mine. its just not comfortable.
too cramped for leg room. would take major alterations
on the seat track to gain a couple of inches. anyone done
something to theirs?---irv
This is why I like being 5'9" and 155 lbs. I fit in cars :p
