Topic: 1988 TC single Holset turbo 5.0/ 4R70W (Read 373257 times) previous topic - next topic
Reply #1110
Quote from: thunderjet302;428576
Sounds like fun :). I bet the engine makes somewhere between 325-350hp without the turbo. Most 302, GT40 intake, Twisted Wedge 170/Edelbrock Performer/AFR 165 headed cars make in that range.
Well, anything over 250 N/A would be pretty nice since I have the power adder for when I want more. All I have to do is press harder on the gas!
Reply #1111
Jim
Your Turbocoupe is one of my favorite car builds of all time....agreed on the bad heads and the wasted time and $$...sucks....moving on.
It will be fun this spring when the weather gets better.
Travis
Reply #1112
I may rank until yours is done. After that I may not medal. reminds me of the Olympics!
Reply #1113
Jim....I may have for power.....but with all those electronic details....its a super sweet package.
Travis
Reply #1114
Hello Jim
How is the TC doing?  How is your summer?
I really just started working on mine again sense last October....still lots to do...but getting there.
Travis
Reply #1115
It's doing well. I had to replace the O2 sensor. I used break in additive with lead in it and it took out the sensor. Otherwise no issues to speak of. I am needing a pick-up truck, so I am going to advertise the Tbird this fall.
I hate to sell it, but I need to cull the herd a bit for garage space.
I still have a couple little things to do to it before I sell it. Nothing big, just detail stuff.
It really runs good. I'm happy with it.
Reply #1116
Well that is good to hear....good luck selling her....or maybe I should say don't sell her....LOL
Travis
Reply #1117
Hey Jim
I was watching your videos from a while back...what year tach do you have installed?  Also how did u modify it for V8 use?
Thanks,
Travis
Reply #1118
Quote from: turbotrav;437340
Hey Jim
Thanks,
Travis
It's a 86 I believe. It is stock with input from a relay pulse generator taking a 1/2 pulse output generated from a Megasquirt output.
Reply #1119
So this is something you modified with in MS???  or an additional part...
Travis
P.S.  my car is an 86 so I currently have that model
Reply #1120
I built a circuit detailed in the megamanual that takes an input pulse from MS and turns it into a 'dirty' negative pulse that the tach can use.
Since I am using a 4 cylinder tach, I used a handy divider in MS that cuts the generated pulse by 2 from the V8 signal. The tach needs to see a big spike to read, so just using the MS signal isn't enough by itself. You must add a relay coil to pulse to ground to get enough to read.
I have built 3 of these and they all have worked well and reliably.  They are noisy htough. If you put it in the cabin you will hear it clicking.
Reply #1122
Hey Jim
I contacted stinger about the PIMP.....they suggested I could just make an adjustment within Microsquirt. ....I will see.
Thanks for the help....
Travis
Reply #1123
Hi Jim. How's the car doing.  I've started a  ms2 swap  and want to do the tach mod on my tc. Could use your help?
Reply #1124
I thought there was a way to double the tach output htrough the tuner studio software...
Travis
