Topic: 1988 TC single Holset turbo 5.0/ 4R70W (Read 371524 times) previous topic - next topic
Reply #1095
Turn up the boost.....Are you thinking of tuning for 12psi?
Travis
Reply #1096
I think that would be safe enough, yes. Somewhere in the 12ish psi range. I'd like to check the backpressure to see where that's at.
First I need to re-do the vacuum venturi so it actually sucks. It can be a challenge to get it just right based on what I see on the inter-web. I'll keep at it until I get some results. Luckily the downpipe isn't too hard to get off and on.
I have to pull the instrument cluster and install the solid state regulator I got as well.
I got the carpc back in and am playing with it to get all the features working. The new steering column control stalk will be here Monday and I can get that on. That ought to bring the car up to speed on the inside.
Reply #1097
You must be joking.
Alternator died after 150 miles without header wrap. The wrap is going back on.
Hopefully the coating will help delay the rust issue. It seems to be holding up where I prepped well, but doesn't do as much for heat reduction as the wrap. It's just too tight around the alternator.
To be fair, I've been hearing a squeak up there at times, and it was a JY alternator. I'll go get an Advance or Autozone new replacement and get the lifetime warranty in case I have future issues. I won't mess with their reman electric stuff.
Reply #1098
Quote from: flylear45;427513
You must be joking.
It's always something, isn't it Jim?
Reply #1099
Good luck with the alternator. I've had nothing but problems with new and rebuilt. From now on I'm rebuilding my own. Cant do any worse
Reply #1100
Quote from: Chuck W;427517
Oh boy, howdy! The bright side is I saw it near the house and got here with just over 9V left. It was missing but MS didn't drop out.
It turns out that I had two things going on. I put in the new alternator and was still showing battery voltage. I scanned the wiring diagram and the first connector I checked was starting to come loose. I probably had an intermittent problem that helped take out the old alternator. (I had it checked and she was a goner.)
So now with a fresh alternator and some wrap on the adjacent pipe I should be good to go again.
Quote from: thewestie;427541
Boy that's the truth. The 3G I got new from Advance for the TR7 is holding up fine. AZ didn't have a new one in stock so I took the Premium Lifetime Reman. I was told if it fails I can pay $20 and upgrade to a new one. I had a 20% off coupon and $8.00 in bonus cash from using my AZ card, so it came to $130 out the door. Luckily it's not golf season. lol
I have a spare here I want to try to find a regulator and brushes for. I wish now I'd have done it sooner. I just wanted to get it done this time.
The car is tuning up well. It is idling and driving better and stronger than ever. Still no leaks.
Reply #1101
I've put another couple hundred miles on her and she starts up and runs great even in the brutal cold. The carpc even comes to life in this extreme weather when I would not expect it to.
I just need to keep tuning and get the next set of parts on to get serious about seeing what this combo really is. I.E. dyno and track times!
Reply #1102
I made a quick video going over the new frontend software I have installed on the Foxconn barebone pc in the trunk.
It starts out dark, (I wanted to give the screen a chance to look it's best) so give it a second.
https://www.youtube.com/watch?v=hLFPpk13zzE
Reply #1103
That's pretty cool
Reply #1104
Nice buttons
Reply #1105
Quote from: thewestie;428035
Nice buttons
I LIKE me buttons!
I volunteered to write a users guide for this software. Gratis. I love a guy who gives so much to his users just because he CAN!
Quote from: STANG8U;428007
That's pretty cool
Thanks, I get a kick out of trying to make the old girl live up to today's standards.
Reply #1106
That things looking more and more like a pen 15pit every day ;) That bird might grow wings
Reply #1107
I watched the youtube video...pretty dang cool...more than my carputer i devised....goodjob Jim.
So now you are using premium...lol...how is she running?
Travis
Reply #1108
Still tinkering with the tune, Travis. And running out the 89 octane. Cold starts are getting better but take the longest time to get just right because you only get one change per day basically. Because I am ic in nature I drove it to work and left it in the lot for 3 days when it was the coldest. It started up for me when I got back, but died 3 times on the afterstart enrichment after 10 seconds or so before it got warm enough to idle strong.
I left it again this week for 4 days and it died once before catching in 17 degree weather, so it's getting closer. Like I said, the only way to tune it is to use it in these conditions. Once I get it it should always work. The TR7 tune is super solid and starts before the engine cranks over twice in all weather. (It is using the open loop fast idle, which is MUCH easier to tune than closed loop, though.)
I did a hundred foot burnout in front of the house the other day after I had THOUGHT I was tuned in on the fuel and spark pretty well, but it rattled on me while feathering the throttle at just over 1/2 and I immediately lifted. I reworked the timing table a bit where I had the issue and took a datalog that I still have to look at. No WOT other than that one burst so far. Wastegate is on the spring alone and is around 10 psi and holding steady.
Otherwise, aside from still needing to rework the breather venturi tube, all is well. No leaks at all of any kind and it runs nice on the highway. I only have a 1 pint overflow bottle and it never pukes any fluid out of it and the rad stays full. YES!!!
It takes almost no throttle to travel at highway speeds. I am curious what power it makes even without the turbo.
The to-do list includes installing a new 256g SSD I picked up to replace the HDD in the PC for faster boot times and lower power consumption, removing the dash cluster to install the solid state IVR and remove the ABS fail light, gluing down the dash top cover, and getting the auto headlamps to work. I love that feature on the Milan and would like to have it function in the 'bird, too. I have to paint the side moldings, then installing the trunk carpet and finally adding A/C will finish it off.
I got some nice 31 spline 4-lug hardened axles in the right length from 86tbird, and am looking for a diff to put them in along with a brand new 31 spline trac-loc. I'll weld the axle tubes on it when I do it. Ideally I want to prep a complete axle and just swap it in when I am ready. Hopefully I can come up with a stout torque converter by then as well and do it all at once. Until those parts are in I am taking it pretty easy on it, but not babying it completely, either.
 I am considering adding a dash cam, parking curb cam and a pen 15pit cam that I can set to record on a loop while I drive, and/or select for viewing on DriveLine. Not sure about that yet, but cameras are getting pretty cheap and I like toys.
The DriveLine software is really nice on the carpc. I have everything I need now, or want. It is fast, stable, and easy to navigate. (And free!)
Too bad I screwed around with bad heads for so long. I wasted a lot of time on that and got discouraged to boot for a while. I pretty much love the thing now, though. Hard to imagine it as it was when I drug it here way back when.
Reply #1109
Sounds like fun :). I bet the engine makes somewhere between 325-350hp without the turbo. Most 302, GT40 intake, Twisted Wedge 170/Edelbrock Performer/AFR 165 headed cars make in that range.
