Topic: 1988 TC single Holset turbo 5.0/ 4R70W (Read 372468 times) previous topic - next topic
Hey guys. I've been doing this build for a while, but thought I'd relate some progress.
The car is a real nice 88TC I bought in pieces. Dash out, engine, trans, fuel tank, most everything off the car except the rear end and trunk lid. I towed it home with MANY boxes of parts and it has sat here for a few years.
Recently I bought a 4R70W OD trans for it and an Explorer engine for a donor. The engine ended up needing too much, so I went with a rebuilt 87 'stang long block, using the accessories and intake from the Explorer.
Picked up a Holset 351VGT turbo and a set of BBK shorties and went to work.
Chuck's mounts and a shot of the turbo and rear of the car:
Prepping pan for turbo drains, checking bottom end, and bolting on transmission. I had to swap the transmission rear extension for one off an AOD to accept my driveshaft.
Swung in the engine and checked fit of the Explorer radiator and NPR IC.
I didn't have the correct trans crossmember so I modified the Tbird one to fit. The exhaust will be a single 3" coming down the passenger side.
Next I found a spot for the BIG honkin' turbo, and made a cut or three.
Then started on the hotside fab. I had a lot of problems getting any kind of decent welds, so don't give me too much grief!
More hotside fab.
More fab shots, and the turbo brace. I'm going to reinforce the brace a bit more.
Now the downpipe.
Add a 3" v-band for spark plug access and complete the pipe past the starter area.
Add in the wastegate piping.
And finish weld the pipes.
This is where I am now.  What do you guys think?
Make me one too? lol j/k
Looks good, and sweet  that's a big-assed turbo! lol
Now that's a ton of engineering and fabrication!  Great project!
