Topic: Cat Jam 2010 Drag Racing (Read 8892 times) previous topic - next topic
Quote from: Lightningbird;274548
Bring a helmet, battery is tied down, all lug nuts in place, tires are not bald with wires hanging out, seat belts operable, no longer than 12" consecutive rubber fuel line....
what's up with the fuel line?  you can take your car to the track if you have the stock lines right?
Count me in as well...  King Cars  I'm calling you out for my first race.  LOL.  would be a fun run.
Quote from: mywifeskitty;276310
Stock fuel lines are fine, the NHRA rules just state that it cannot have a splice of 12" or greater of just rubber fuel line. SO what that means is that if you have a different carb and the fuel line is some cobbled turd running from the pump to the carb made entirely of rubber line, you need to fix that or you will not be able to run. This is just the NHRA rule, and most governing bodies for that matter, not to say the same exact rule would be applied at the track. Most places will not allow that to run at the track. Show up at the track to fit the rules that I had stated and you will be fine. No one would drive all the way to CJ to drag race and not be prepared to get in.
Quote from: 1WLD BRD;276326
LOL, thats great this is going to be fun. :burnout::burnout:
Do we have any idea what date?/month? yet
trophies are done ill post some pic soon im finshing the cam shaft lamp too ill just save it for when ever
if its fine if i run my auto 99 because if i come it will most likely be in that id be in. Yeah go ahead and laugh but im going to get it dynoed soon a local speed shop does it for 2wheels for 80.
hope i will have the car done by then. should be starting it soon:burnout:
88 5.0L aod with duel flowmaster and speedo mod
88 5.0L H.O with 5 speed R.I.P
87 3.8L no trans. geting h.o and 5speed (project never ending thunder) started it as of 8-14-10
96 bronco xl 5.0L 5 speed man4x4
:birdsmily:
Good luck guys!  My luck I'd get there, get going, blow the engine or tranny, and have to figure a way home, lol.
1987 TC
Quote from: EricCoolCats;274413
It would be a Test-N-Tune night...so there will be all makes and models running. We'd have to keep tabs on all of our own cars, motors and mods.
Not that I expect ANY OF THE NEW YORKERS TO ACTUALLY TAKE THEIR CARS OUT ON THE TRACK AND RACE THEM. Noooooo, not when the Desktop Dyno™ is just as good! Just plug in the specs and BAM! The approximate estimates are just fine! Why go out on a track and do the actual work! Never mind the fact that I take my irreplaceable 1-of-1 convertible to the drag strip every once in a while. Where would the fun be in backing up what you say, when just saying it should be all the proof you need!
:flip: :flip: :flip: :flip: :flip: :flip: :flip:
Yes, I do believe that was me calling out the NYers. There's money on this, beotches...let's see if you can step to the plate for a change...
I know you aren't calling me a NYer. LMAO
And, for the record...I'm not letting Roger in on this.... we don't have enough life insurance to let him race! lmao (don't tell him I said that)
:cougarsmily:~Karen~
