Topic: Cam swap: It doesn't end at the cam.... (Read 11277 times) previous topic - next topic
Reply #60
It's nice money for a few min of work. But it saves hundreds in the long run
Reply #61
Quote from: V8Demon;279745
I don't feel like paying for a Lenco yet.  ;)
Teaser.....
How is your distributer boot so black? ;) Did you paint it?
Reply #62
I did a dodge and burn on the jpeg but my boot IS blacker than most I see.....
Junkyard special -- $5. ;)
Reply #63
According to my timing light, idle in park is 920-ish, 780 or so in drive.....The rev up is to 3500 RPM.
Enjoy!
http://www.youtube.com/watch?v=QhouoYcsDJI
Reply #64
Sounds awesome paul. Whats your exhaust setup?
MODS: cone filter, no cat, flowmaster dumped, boost contoller, 4:10s
Reply #65
Mac equal length shorties & H-pipe, Borla XR1 lers dumped before the rear axle.  2.5" pipe.
I should add -- that was a dead cold startup.
Reply #66
That's a nice cold start, That improved on mine to. the e-cam I had would never idle on it's own when it was cold. did you make it idle that high?. I'm right at 800rpm it was set that way for the E-cam, I want to try and lower it . Good job sounds good.
Reply #67
Yeah I put the idle there.  MY issue was actually a hot start.  It will stay running, but will hunt if I go too much lower.  I could probably drop it 50 RPM....
Reply #68
It's louder than mine ;) It sounds good :D
Reply #69
Oil cooler on order from Summit.  Should be here Friday.  Dent removal guy comes tomorrow.  I pick up paint/primer and accessories  on Monday and some fun begins next weekend if all goes well :evilgrin:
Reply #70
You're painting the car Barney purple right? ;)
