Topic: Cam swap: It doesn't end at the cam.... (Read 11273 times) previous topic - next topic
My buddy's 02 GT in which he grenaded the motor last weekend.  Stage 2 Patriot heads, comp cams with upgraded springs, 4.10's spec stage 3+ clutch, strange axles, all on a stock block....
2 weeks ago he decided he wanted to put on the HP performance TT kit he had for the car.  We knew that would be the end of the block, but wanted to see just how much/long it would go.
Twin 50mm turbos with 60 pound ijectors and a boost controller set to 13 PSI mad 580hp/604TQ at the wheels.  He set it back @ 8 PSI which made just under 500 hp the tires...
Got it home and drove it 2 nights with no problems.  Took it out last sunday and eased it into 4th @ around 50 MPH.....
[SIZE="7"]KABOOM! LOL![/SIZE]:hick:
He's found a low mileage Cobra shortblock block for $800 to swap in and put all the other goodies on.  We'll be doing that the weekend after Carlisle.
She's done!
:evilgrin:
[SIZE="1"]Pics later......[/SIZE]
Yey. Good to here.
Well that only took 2 months ;)
Quote from: thunderjet302;279371
Sometimes it takes time, been there.
Quote from: Kitz Kat;279378
I know I'm just messing with him ;)
Yeah, With the car not in my driveway, I wasn't too ambitious....
Due to that I have 2 dents to pull.....Very minor, but still......
On top of the trunk and another on the hood.  No paint damage.  Can't see them from 10 feet.  It looks as if someone may have actually stepped on the trunk....
any pics man. i wanna see it done.
MODS: cone filter, no cat, flowmaster dumped, boost contoller, 4:10s
Not yet, Jon.  I'll take some tomorrow after a bout with the dent puller and some elbow grease to clean her up.
Reply #39
how do you like the cam?
Reply #40
My first impressions are positive.  It was a bad day to test it warm, humid and a horrid DA, but it hits hard in the midrange and up high.  Off idle feels the same. I have to do some fine tuning, but it's good so far. I'm seeing 14" of vacuum in park @ 900 RPM on my vacuum gauge which reads less than zero when off so that's a good sign.  Highway mileage seemed better according to the tripminder.
Things I have to do:
-Reset base idle/TPS.  It's set,but I didn't check the voltage.  I have a feeling it's out of whack due to the car not wanting to stay running at idle on a hot start.  I have to give it some gas or throw it in drive after starting it before it goes from startup to normal idle or it will stall.
-Clean the valve covers  I'm amazed at how dirty they got from rain water.  It's almost like a calcium deposit.  It's gonna take the buffer to get it off in a couple of spots.
-Change the oil & filter  I put Shell Rotella 15w40 in for a break in.  We put a fram filter on.  Iv'e discovered my car DOES NOT LIKE this combo.  Rotella gets water thin quickly and the drainback valve in Fram filters makes your oil pressure ever so slightly less than with a better filter.  I've had an interesting anomoly with my oil pressure warning chime since I've had the car.  Most go off and ring @ 7 PSI.....Mine does it at 20.  I've verified this time and time again.  The cam lube didn't help any as it's thin to begin with as well and I used ALOT.
Time for a mobil one filter and the 15w50 I run this time of year...
I'm going to try 10w50 this winter or if I can find it 5w50.  I know Mobil and Castrol used to make it.  60 miles is enough on the break in oil.  I'm sure there's a bit of tranny fluid residue leftover in it from the flushout as well.
Reply #41
15W50? Really? I run Mobil 1 10W30 and have fine oil pressure. Why such a heavy weight oil?
Reply #42
Motor is a rebuild with larger clearances.  I can run 10w40 in the winter, but this time of year I need something a little thicker...at least to keep the  chime from screaming @ idle anyway...In the summer I get 17 PSI @ hot idle and the chime rings.
I can beat on the 15-50 all day long too.  The majority of the problem is the oil filter.  Can you say 4 PSI @ idle from a different filter?  I've seen it going from a Fram to a Bosch.
Reply #43
Glad it's running again...
But I have to ask, is/was the swap worth all that hassle??? For myself, I know the the answer is a definite no...
Reply #44
That remains to be seen....
