Topic: Cam swap: It doesn't end at the cam.... (Read 11339 times) previous topic - next topic
Reply #45
Oil change complete.  I was surprised at the amount of trans fluid left over....I flushed it twice already.  Beeping stopped.  Figured out the hot start issue.
Of course I get it running right and it starts to rain....24 days in June 22 with tons of rain......
This is looking to be the worst summer in over a century up here.....
My pool temp was in the mid 80's by this point last year.  It's currently 68*
FAIL.
Reply #46
Quote from: V8Demon;279515
Motor is a rebuild with larger clearances.  I can run 10w40 in the winter, but this time of year I need something a little thicker...at least to keep the  chime from screaming @ idle anyway...In the summer I get 17 PSI @ hot idle and the chime rings.
I can beat on the 15-50 all day long too.  The majority of the problem is the oil filter.  Can you say 4 PSI @ idle from a different filter?  I've seen it going from a Fram to a Bosch.
When my engine was rebuilt it was rebuilt to factory clearance specs (for good or bad) so I run 10W30 in it. I know FRAM filters suck (why would you run one ;)) but have you tried running a Motorcraft FL-1A? I always run those on my T-bird.
Quote from: V8Demon;279544
FAIL.
Oh rain and cold temps......how I hate thee. We've had the same problem here. It's been rainy and cold till about 6 days ago. Since then it's been in the 90* range with a couple of pop up thunderstorms. Worst summer evar :hick:
Reply #47
After reading numerous tests, I feel the Mobil one and Bosch filters are actually a better filter now.  The Motorcraft filter was redesigned sometime in 2007.  While it's still an excellent product, the supplier ( Purolator) has cut back a wee bit.
Here's a very comprehensive oil filter study.  http://www.knizefamily.net/minimopar/oilfilters/reference.html
And yes. This motor was clearanced a bit on the loose side ;)
Reply #48
I'll be sticking with Motorcrafts for a while. I still have 4 of them from about 3 years ago sitting in the garage from when I bought a case (12) of them;)
Just currious but why was your engine clearanced on the loose side? Was there a performance advantage to it? Just wondering.
Reply #49
Many built motors go loose.  In 2001, the plan was to use forced induction.  To be honest I'm happy I didn't go that route with this car.
Reply #50
Paul, any pics yet? How does she run? It better go low 12s. lol
MODS: cone filter, no cat, flowmaster dumped, boost contoller, 4:10s
Reply #51
Glad to hear she's going again Paul..................now we need some pics and a verdict !!!!!!!!
Reply #52
Quote from: flipnbird;279631
I think video would be in order for this swap
Reply #53
I can do that.  Gotta go into work tonight and I wanna clean it and pull the dents first, so figure --- Saturday?
Reply #54
Quote from: V8Demon;279575
Oh ok the engine was originally supposed to get a blower. That blower ended up on the Mustang ;) It's never too late to supercharge the Cougar.....
Reply #55
I don't feel like paying for a Lenco yet.  ;)
Teaser.....
Reply #56
Pfffft....showoff. Vid or never happened! lol
I just had to do it:mullet:
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
Reply #57
Take note of the valve covers -- specifically their height, and notice that the intake actually clears them....  ;)
Seems I'm gonna need some help with my 2 dings.  They defeated my suction cups.  There are paintless dent removal guys that make house calls.
On a side note,  I'm grabbing a batch of urethane paint tomorrow for my next project.....
:evilgrin:
Reply #58
Those PDR guys are real good, but expect to pay them well.
Reply #59
Should run me about $150 or so....
