Topic: fuel leak (Read 2266 times) previous topic - next topic
fuel leak
My 88 Tbird has been parked for the winter. It has developed a nasty fuel leak, it appears to be coming from the center of the fuel tank, and from the general location of the fuel pump, it also only leaks when the car is running.
Any ideas before i get her in the air to take a peek.
Thanks
Jeff
fuel leak
I take it that the leak is on the top side of the tank then?
fuel leak
Yes the leak appears to be coming from above the tank.
fuel leak
It sounds like the seal right above the fuel pump. You're going to have to drop the tank to change, you might as well change the pump while you have it down.
fuel leak
Could also be one of the lines going in right there as well.
fuel leak
Watch out for those people in front of you throwing their cigs out the window. . . . . It could be an explosive situtation!!
Wouln't that suck.
===85BIRD===
:birdsmily:
fuel leak
Quote from: 85bird;264878
Wouln't that suck.
You know thats a common misconception from movies that cars explode. Cars don't explode, they just spill the contents of their gas tank after it melts then burst into flames. Far from an explosion.
fuel leak
Replace the big o-ring and the seal for the return line.
fuel leak
Since it only leaks when the car's running I'm gonna put my money on it being the lines. More specifically, the nipples on the pump hangar, where you attach the factory plastic lines.
fuel leak
It's a line,You got to go under and look.
Show where your from.
fuel leak
Mine was fine siting still because the gas wasn't moving,but when I'd drive,the gas was sloshing around and it would make it's way out of the seals.While the tank is down,that's the time to check everything,also the seal on the side for the filler.Let us know what you find.We need an end to the story.
fuel leak
I will let you know what i find, i had the fuel pump changed 3 or 4 years ago (with a new one) so hopefully its just a line or lose connection.
Jeff
fuel leak
Hello everyone
In the end it turned out everything but the fuel pump was shot. So i got a new tank, lines, sending unit and home made straps to hold the tank in.
$640 canadian dollars later and all is good.
Time to go take her out for here first cruise of the year.:burnout:
