Topic: 1988 3.8 wiring (Read 4728 times) previous topic - next topic
1988 3.8 wiring
i need the COMPLETE wireing harness for a 1988 or 87 cougar everything from under the hood through the firewall connected to the fuse box and everything under the dash.
1988 3.8 wiring
You'll need the 88 only.  The 87 still had the CFI 3.8.
1987 Thunderbird 3.8. Sold :(
1988 3.8 wiring
If you read the thread where jcassity talks to him, he says theres only 4 wires different.
1988 3.8 wiring
so does that mean i can use the 87 or i have to use the 88?
1988 3.8 wiring
Quote from: amooset;263109
Thers's your answer bud
FOXLESS!!
1994 Lincoln Mark VIII
1988 3.8 wiring
Quote from: Haystack;263111
Yes it CAN be done that way, but it will be enough work to just swap over one that is exactly the same let alone having to do some minor rewiring.  Direct plug and play requires an 88 harness.
1988 3.8 wiring
I have a good 88 V6 harness if you need it....let me know
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
1988 3.8 wiring
Yes I need it
1988 3.8 wiring
What's your zip? I will calculate the Cost + Shipping.
1988 Thunderbird
1988 3.8 wiring
1988 3.8 wiring
are you going to send the wires??
1988 3.8 wiring
I sent you a Private Message. How's $50 including shipping?
1988 Thunderbird
1988 3.8 wiring
Quote from: 88BlueBird;264525
sorry didnt get it but thats fine but i dont have pay pal or any thing like that so is it any other way like money order or sumthing?
1988 3.8 wiring
Let me dig the harness out of the garage tomorrow. A money order is fine.
1988 Thunderbird
