Topic: 1988 3.8 wiring (Read 4724 times) previous topic - next topic
1988 3.8 wiring
Quote from: 20thanniver-ls;265121
You would have to re-pin it for your base digi cluster
that isnt that hard is it.. isnt that just re connecting those two harnesses that go into the back of the digi speedometer?
1988 3.8 wiring
Yeah, basically it would be. Tell ya what, if it's warm this weekend, I'll pull the dash harness from the white car, repin the wires  to the cluster as they were originally, take lots of pics, and get it sorted out. Bad thing is, I sold my base digi cluster awhile back, so I have no way of testing it to make sure it would be back as it was.
It's not a huge job to repin the wires, there was only 4 or 5 to do IIRC.
There's a digram on CoolCats.net that shows how to do this.
I can repin 'em, or if you feel comfortable doing it, I'll send it to you as-is, your choice. Either/or is fine with me.
1988 3.8 wiring
what does IIRC mean? Sorry, you guys always say it and I don't know what it means.
and I have the harness from the computer that goes across the firewall and plugs into the dash harness.
1988 3.8 wiring
If I recall correctly
if I read correctly
if it really counts
1988 3.8 wiring
Quote from: jpc647;265233
is it for an 88 3.8 v6? is it for a digital speedometer? and does it have the fuse block attached and the rubber piece that leads the wires through the firewall into the hood?
1988 3.8 wiring
Quote from: FordTruckFreeek;265215
that would be great just let me know when youre finished and a price
1988 3.8 wiring
If it's color coded I could probably do it I just need the wires asap to get this thing up.. I have a pregnant girlfriend that needs odd things at odd times lol so no transportation of my own is geting kindof hard
1988 3.8 wiring
any body had any luck on getting the harness together to sell??
1988 3.8 wiring
Quote from: 17needhelp;265276
It is the section from the passenger side kick panel with computer which runs across the firewall and comes to the dash plugs. It was for a car with a digital speedometer. It does not have the fuse block attached.
1988 3.8 wiring
Reply #39
i dont think thats what i need i need the dash harness that goes into speedometer, radio, a/c and ignition and the other plug ins under the dash and the wire harness i need has the fuse box attached.. all the wires are coming from the fuse box
1988 3.8 wiring
Reply #40
this is the piece i need
