Topic: advice for installing a dead pedal? (Read 1809 times) previous topic - next topic
If you've done, do you have any recommendations?
__________________
Twin '85 TCs
White/ Grey 2-tone
Pull the driver side kick panel off,locate where you want the pedal and hold the kick panel over it so you can get the pedal where you want it without having to trim the kick panel.Once you figure out where you want it,drill two holes and use some self tapping bolts (giant screws?) to hold it on.re-install the kick panel.....done.Takes about 10 minutes or so......
This was taken during the 5 speed pedal installation......I'll have the new Steeda pedal covers on next week...
what pedal did you use?
1987 TC
Vinnie, is that touching the floor or above it. MAybe its the picture, maybe my eyes, I can't tell. lol
It's above the floor as if it were magically suspended in air.LOL.
Vinnie, is that pedal from a Mustang?  Do you have any trouble with the parking brake?
__________________
Twin '85 TCs
White/ Grey 2-tone
The dead pedal IS from a Fox Stang,and there are zero issues with the parking brake.Install that thing and call it good.I drilled the holes probably a little smaller than I should have for the two bolts,but,the bolts went in wicked tight,and it's (the pedal) on there solid.
Whats it used for? looks crowded to me.
It's just a left foot rest. Saves the carpeting from getting scuffed up in that area. Even with the e-brake pedal being in that area, it still doesn't interfere with anything. Nice to have. Standard equipment on the Mustang, we got the shaft, therefore we must upgrade.
Still looks crowded, I have long legs so it don't do me any good.
I plan on doing this mod if I get the XR7 that I have in mind.
BTW, not all Stangs had this. GTs had them from '87 and up and LX 5.0s from '90 and up.
I put one into my 89 LX 5.0. Got it out of a 90's GT that took a pole on the driver cowl. A friend helped me get what he could. He said "I got it." and hands me the pad. I retreieved the base. It was bent up enough that it took a hammer and a vice to straighten.
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
All of the dead pedals I bought came from 4 cyl. cars.
My car has a factory dead pedal. It's the one furthest on the right. You  push on it and nothing happens. I'm hoping the HO upgrade will take care of that problem :mullet:
Quote from: vinnietbird;286640
I was not sure if the 4 bangers got them from '90 on up. Thanx for thre info. I just got one from a C4C 97 GT. For some reason, the SN95 Stangs have loose dead pedals.
2003 Marauder 300B
