Topic: advice for installing a dead pedal? (Read 1823 times) previous topic - next topic
The SN95 Mustangs use the same dead pedal as well. I keep forgetting to snag one when I go to Pick-A-Part.
Also, if anyone sees a Fox Lincoln in salvage yards you might enjoy the the aluminum brake pedal trim for the automatics. It says "4 Wheel Anti-lock Brakes"
but who cares. Another tip, change out the accelerator pedal assembly for a SN95 Mustang type.  This gives you the option to add the aluminum pedal trim available for those cars.
Anyway here is the Fox Lincoln pedal trim in the picture. The "4 Wheel Anti-lock Brakes" lettering is washed out with the flash in the photo.
I find it interesting that an SN95 was accepted as a C4C!  Imagine all of the suspensions that could potentially end up in the yards....or worse, crushed.  I better start looking. :rolleyes:
1987 TC
