Topic: AOD trans build (Read 1110 times) previous topic - next topic
AOD trans build
i would like to build an AOD trans that should handle about 400-450 ft lbs of tq.  i am curious as to what internals i should upgrade.  i figure on using a hardend input shaft and racing clutches.  i am planning on using a full manual revers pattern valve body. what is the next weakest  link inside the trans???
86 t-bird 226k miles and blown transmission
AOD trans build
Here's one place to read, try searching  for a answer it was asked many times.
http://www.foxtbirdcougarforums.com/showthread.php?t=20901
AOD trans build
sorry will do alot more searching next time
AOD Questions
If you have any questions about AOD's, do yourself a HUGE favor and visit http://www.clickclickracing.com/forums/
A guy in that forum named Dan, who goes by the screen name "Siverfox" has to be the most knowledgeable AOD builder I've ever seen.  He can answer any question about AOD's you might have.
Go to the "General Click Click Tech" forum.  That's the forum dedicated to AOD's.  There's some good reading in there.  Enjoy!
William
AOD trans build
Dan is the BEST to talk to about the AOD
hes creating a custom rebuild kit for me with VB and many other parts, and his buddys at dirty dog performance are gonna be doing my torque converter
