Topic: odd idle (Read 1272 times) previous topic - next topic
odd idle
OK, well my cars finally running well after fighting it for a week. But now if it idles for more than a min or two itll spudder buck and die, but itll fire right back upo and idle for a while again before it dies.  Its not dieng at like stoplights, its more like your stuck n the taco bell drive through for 5 min(:punchballs: ) then it dies.  Also when your in park or neutral and rev it past say 3k itll die on its way back down.  I ordered a IAC valve from my work but i wanna know what it could be before i drop 60 bucks on the wrong part.:toilet:  It also idles at about 1200 when i thought i read it should be 900ish
odd idle
have you checked for any vacuum leaks??
86 t-bird 226k miles and blown transmission
odd idle
I have not found any, or any obvious ones.
odd idle
What drivetrain is in your car?
Unbolt the IAC and spray it out with carb cleaner, hook back up and set your base idle correctly, according to whatever engine you have.
Unhook the neg post on your battery for about 20min and rehook and drive awhile.
Mike
odd idle
sometimes it's not the iac, but the channels in the throttle body that the iac feeds......  also, i'm sure you checkes, but the intake throttle butterfly valve might be caked up with carbon too.... i'd clean the throttle body good before i bought parts
odd idle
OK thanks everyone!
