Topic: Boys and Girls, use motorcraft wires... (Read 4645 times) previous topic - next topic
Well, in your turbo cars at least
i was on my way home, and a tibby pulls up next to me, not wanting to have to be behind me at a merge, he launches at the green light, i boost hard, start to pull, then it starts to miss badly, throw second, starts to miss badly again, grab third, my front bumper is at his rear, top of third, it misses bad, and he gets ahead, i throw 4th and stay in it, and kept almost running him over, in 4th, the car had enough to be faster, but i couldnt get around him
moral of the story, use motorcraft wires, or be a tool
Re: Boys and Girls, use motorcraft wires...
What were you using during the race?
Yes... I'm thinking my "Xact" brand wires are failing me, too.  Even though they're new, the car sort of falls on it's face at 4200 RPM.  Good thing there's already motorcraft plugs in 'er.  Time to go to rockauto and order some.
PS - I think he was using Autolite wires.
Quote from: Tbird232ci
. . .use motorcraft wires, or be a tool
hahaha, like it makes a difference for you, HAHAHAAAAAAAAAAAAA!!!!!!
Duckin' agents like we was trapped in da matrix!
I've got autolite plugs, and fms wires. No problems yet :dunno: .
autolite plus and ford wires is the proper stuff to use
Wait... so Motorcraft plugs aren't as good as Autolites in a Turbo?
motorcraft plugs and autolite plugs are the same thing, but the plug wires are different
Motorcraft wires must be good. The ones in my T-Bird are 17 years old and it still runs like a new car. I'm thinking of replacing 'em with FRPP 9MM red wires this spring, though - had good luck with those wires on my Cougar and 87 Sport
TCCOA preaches that fact too.  Only use motorcraft wires on the Turbo Coupe.  When I had the 87 TC, I put on a used set of accel wires.  They worked well for the 1 week that I drove the car.
Um, I have Taylor wires in mine, they've been through a fire and the car doesn't miss a beat... just don't use  and you're fine.
FRPP 9MM blue here.  For plugs I use (Dare I say it?) Bosch Platinums.  They seem to last longer for me.  Don't know why.....
I use the motorcraft plugs with the Ford Racing 9mm wires. The wires are red to match the MSD cap and coil. Have not had a problem yet. Might upgrade to Platnuim plugs later on.
Moroso wires and autolite plugs. Maybe it has to do with each individual engine, but I don't care for the platinums myself.
