Topic: Boys and Girls, use motorcraft wires... (Read 4637 times) previous topic - next topic
Re: Boys and Girls, use motorcraft wires...
Maybe certain plugs work better with certain wires :dunno:
FRPP wires and Bosch +4, work great. :ies:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
I used Bosch platinums with the FRPP 9MM wires on my '87 Sport and it ran like shiznit. After hearing horror stories about 'em I pulled the platinums and installed a set of Autolites and it ran like new again
I've got Motorcraft  9 mm race wires, and no problems yet.
1988 Thunderbird
5.0 HO, t5, TC rear, TC brakes, etc. - Gone
I have Bosch Platinums in my 3.8 and I have had no problems. They even worked fine when they got drowned in oil from the clogged PCV valve.
but also remember guys, youre in non-boosted applications
ive been told that with even some decent, non-motorcraft wires, the boost is able to "blow out" the spark since the wires arnt able to conduct the proper amount of energy, i cant say how true that is or not, but aparantly true enough
hell, in my 3.8L, i have the cheapest wires, and cheapest bosch plugs, and it ran like a champ
Quote from: Tbird232ci
just for the hell of it Shawn what did you gap the plugs at on the TC?
the autolite spark plug number is 764 not 25's or 26's and they get gapped at .034 not .044 or .054 ;)
oh and i think you ment your 3.8 ran like a chump! not a champ :raspberry
i forgot what theyre gapped at, i believe it was .35
it was what was recommended
i Edited my post read again and yes they should be gapped at 35 ;)
I've driven a new Tiburon GT..... you should be ashamed of yourself. I've been in faster Chevettes.
well, thats why i feel like a tool for getting beaten, all because of some plug wires
now i need a credit card to place an order...hmmm
I run motorsport 9mm wires, with autolite double platinum 23's on my combo. Car runs like a raped ape on this setup. MSD box also helps with the spark control.
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
