Topic: Looking for some parts to finish the Bird (Read 1786 times) previous topic - next topic
I need the drivers belt trim that goes behind the mirror and across the door, I need the aluminum trim that goes over the door jamb seal and the carpet, also I need the outer scuff plate plastic. Please let me know if any of you have a junk yard's that might have these parts so maybe it will be eaiser for me to call them to get the parts. Thanks guys for your help.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
I'll check the boneyard tomorrow.
much obliged
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Going friday. Hope the 83-84 Bird is still there. Ill look.
What is this though. Not understanding.
Yeah, I was not sure what it was called this should help
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I understood.It was raining today,so,tomorrow morning will be the boneyard trip.
thank you very much
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
I got the black plastic pieces and the aluminum pieces for the door jambs (both sides).The other parts were MIA.
cool, I called 10 yards and 83-86 birds don't exist. Hopefully I can get that door trim, what do I owe ya
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Is $25.00 shipped fair to you?I also got ONE inner dew wipe from the car which looked really nice.,which I'm sending as well.The outer peices are also called dew wipes.Finding them in tact,with good rubber,supper hard to do.
cool dude, that is more then fair price.
Also does anyone know where I can get the lights that go behind the rear quarter window on the plastic side pannel(interior) opposite of the bird emblem outside
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
please someone.............., anyone.................?????? but for the drivers side
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
i may be able to find one Friday.I'll let you know.I'm following a lead.
I LOVE YOU, in a hetro way :bowdown:
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Right back at ya.....in a non-prison love kinda way.
