Topic: Looking for some parts to finish the Bird (Read 1808 times) previous topic - next topic
Hey, I also need a radio, A/C trim pannel if you see one. My tabs are broken at the bottom and the hood hinge rubber seals if they look good enough to clean.
Thank you
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Quote from: 347Thunder;243868
Thank you
What style on the radio trim?
cubby
radio
A/C
Cigar lighter
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Quote from: 347Thunder;243906
cubby
radio
A/C
Cigar lighter
I ment what color wood grain, brushed alumimum, full console, no console?,I have few different ones laying around.
It appears as though he would need the non-console trim, I'm guessing in brushed aluminum finish.
1987 Thunderbird 3.8. Sold :(
sorry, I need the one with full consol brushed
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
The only one I have has a cracked bottom mounting hole, It still screws down though.
could I see a pic please
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Yeh no problem, you got a email?, I found 2 of them. You can see them here.
http://i446.photobucket.com/albums/qq183/kitzdnm/parts/bezel002.jpg
The one on the right has a slight scratch on the second bar going accross.
how much?
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
22 shipped for either one,I need to keep one of them for mine.
Cool, I might of found one but I will let you know. I have found the door trim I was looking for but thanks vinny, and kitz kat for your help.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
