Topic: Masons stinkin lincoln number 2! (Read 16152 times) previous topic - next topic
Reply #45
just swap the t/b back. be sure to use new gaskets though.
1979 Ford Fairmont
[/B]
Reply #46
Quote from: 32VFoxBird;243951
I only have one gasket on the whole thing, used high temp silicone on the rest. EGR is port matched to the 65mm tb so if i swaped one the both gotta go. I gotta tinker more... story of my life
Reply #47
Quote from: daboss351;243933
only done it since I swaped tb and egr spacer
I think I'd try swapping them back one at a time to see if the problem is corrected. If so, then put the replacements back one at a time to see which is the cause.
you might have thought of that already
5 Mopars, an S-197, and the Turbo Twinkie[SIGPIC][/SIGPIC]
Reply #48
someones got a vaccume leak
Reply #49
guess we all thought about the same thing at the same time huh
Reply #50
since I swapped parts it eliminated the check engine light(egr related) I really dont wanna swap back, because I know im not the only one running a explorer TB so its got to be something else
Post a few DETAILED HI-RES pics of the Explorer TB hooked up to your setup, please.
FWIW I'd leave it.  Why?
Very good chance of that.
Get a vacuum guage and check this out:  http://sbftech.com/index.php/topic,3020.0.html
Before you even do that, disconnect the EVP sensor and EGR vacuum line(and plug/cap the line).  What happens?
Let us know.
Reply #51
Quote from: 87thunderbirdBlackJack;243963
idk it never did it before when I bought it
it idles soild 1350-1400 in park....
Reply #52
Quote from: V8Demon;244002
Let us know.
EVP?? Ill try that and see what it does.
high res pics ill try
I swaped the throttle arm, welded the new one on, rotated the vacuum port, and cleaned it out.
Reply #53
You swapped some stuff around.....Might have pinched a gasket/seal or cracked a vacuum line.  You need to diagnose the situation.
Reply #54
or you can spray carb cleaner around the gaskets, and see if the idle changes.
1979 Ford Fairmont
[/B]
Reply #55
whats the evp?
Reply #56
If you find no vacuum leaks:
1. Use a gasket between the TB and EGR spacer as well as the EGR spacer and Manifold. It will leak either air or coolant into the intake track.
2. Is the gasket between the IAC and TB good?
3. Rest the idle with the screw under the throttle body. Check the voltage at the TPS. As long as it's above .5 volts with the throttle closed and above 3.5 volts at WOT you're fine. Then disconnect the negative battery cable for at least 15 minutes to reset the computer. Start car and let it relearn the idle.
Your car should be fine with just a 65mm TB. Before I swapped to MAF I ran my combo on a '89 Mark VII LSC SD computer with virtually no problems.
Reply #57
freaky
i fixed the dash ground so now my gauges work with the lights on
idle is perfect now, and turns out my gas gauge read over half a tank ABOVE what was in it... I had a little over a half, turns out i had a 1/8 left.....
Reply #58
what fixed the idle issue?
1979 Ford Fairmont
[/B]
Reply #59
the ground wire DID for about 3 times i started and ran the car
now the idle is back up, but sometimes goes down to 850-900 in park
and my rear end is coming apart..... time for switching...
