Topic: Masons stinkin lincoln number 2! (Read 16146 times) previous topic - next topic
Reply #60
tomorrow im gonna try spraying carb cleaner on the joints and see if ones leaking. shouldnt be I just put on a new gasket because it was sucking coolent, but who knows.
Then i will plug the egr vac port, and unplug the sensor on it(thats the EVP correct?) and see what that does. If I get no results then I will try my old TPS, and the gasket on the IAC is BRAND NEW, came with the car, I had to brand new IAC's in the trunk in boxes with gaskets.
Reply #61
Quote from: daboss351;244070
the ground wire DID for about 3 times i started and ran the car
now the idle is back up, but sometimes goes down to 850-900 in park
and my rear end is coming apart..... time for switching...
Your rear end is coming apart? Switching?
My TC has a extra ground cable running from the battery to the intake. Not sure why, but the P.O. seemed to think it was necessary. If the gauges need an extra ground cause Ford in it's infinite wisdom didn't provide one good enough to begin with, then maybe yours need one on the motor too.
5 Mopars, an S-197, and the Turbo Twinkie[SIGPIC][/SIGPIC]
Reply #62
Quote from: Turbo 88;244083
Yea if you take a courner about like 20 the rear end clunks and pops....
need to take the rear end out of my 88 and swap it into the 90.....
my car has enough grounds.... the gauges have a ground mostly for the fuel gauge
when i grounded it first time, the half to the gauges was grounded, but the other half teh wire feel off, everything worked but the gas gauge.
hooked them all up again started the car and they all worked..... its weird....
car NEEDS my new brakes too, they SUCK and one rotor has a warp i can feel the pedel pulsing, o and the check suspension light comes on and off and now the pass bag drops almost every time i shut off the car....
Reply #63
Other than that, it's in perfect shape huh....:D
Reply #64
Just wondering but how's the ignition switch? It *could* cause some of your funky ground trouble.
Reply #65
It was the IAC
computer needed to reset.
Unhooked the battery, swapped in my new one, let it relearn the idle and perfect!!!
re hooked up the exhaust so its quiet, and now the front air ride finally went poof
Reply #66
No worries.....you can find that stuff fairly cheap nowadays.
EVP = EGR Valve Postion sensor
http://fordfuelinjection.com/?p=35
Reply #67
i got a 88 whole car left
swaping in new control arms with poly bushings, my spindles with new rotors, my kyb's, my old air bags/soliniods, and new calipers. Along with a turbo coupe front sway bar. Should handle and stop soo much better.
Reply #68
since when is motorcraft oil, filter, and a new IAC a mod? :/
1979 Ford Fairmont
[/B]
Reply #69
Quote from: 32VFoxBird;244398
... idk I just listed what I had done to it
Reply #70
got the full spindle assembly almost out of the blue car, then got to clean them up, grand them and the sway bar and head out to my grandparents to do the front end swap!!
Reply #71
stupid car is the biggest stupid PAIN IN MY ASS
****ing passenger side bag mount is completely rotted to shiznit, and the  drivers ball joint would come out so its all screwed to shiznit.
Got the turbo coupe sway bar in, with new bushings, one new spindle with kyb in, and one new endlink in.
Need to put in new ball joint tomorrow and finish brake/suspension upgrade....
god  i ave the best friggen luck I swear
Reply #72
Can't you bolt in the Turbo Coupe K-Member and do away with the air bags?
Reply #73
Feel lucky that you have luck at all. It could be worse, you couldn't have a car at all ya know? Good luck, bad luck... luck is luck. You have an 19 year old car... theres bound to be some problems along the way.
Im glad I grew up with no money, I had to learn how to fix things with what I had layin around. If it was broken I'd fix it.
Quit complaining about rusty bolts and busted knuckles and rotted parts and get the  thing done man.
Reply #74
Yea I thought about it last night shiznit happens
got to do what I got to do.
Im gonna make a plate and weld it in the bag mount and see if i can repair it. It sucks but I gotta rig something
I COULD use a t/c k member and springs but screw that
I LOVE my air ride.
