Topic: Masons stinkin lincoln number 2! (Read 16105 times) previous topic - next topic
why did you "unhook" the h-pipe?
1979 Ford Fairmont
[/B]
has stock replacement sucky lers and tail pipes
so i unhooked them so it actually sounds like its running
http://www.westcoastlincolns.net/forum/showthread.php?t=333
bad ass mk7
Well at least you didn't disconnect the h-pipe from the headers. It kind of sounded like you did that.
I'm the one that spent 45 minutes scanning that in btw. :giggle:
Matt
Whats infront of the Buick? Looks good... Now we need more. If you could send more than one pic in a pic message to a phone you could send them to my phone and I can load them straight on Photobucket from there.
haha 54 chevy delray
need to get the AOD shifting right...... and idle down but shes registered
I can not get this stupid car to idle lower!!
it stays at around 1-1200k in park, 850-900 in drive
its g me off, car is sucking gas down at red lights and such
other then that its averaging 13.4 around town
Bad temp sensors?
13mpg....jeeze you could go big block and still average the same....still looks cool and you gotta make a vid when shes done!
[/IMG]
Just enjoyin the ride!!!!
Reply #39
only done it since I swaped tb and egr spacer
Reply #40
swap it back
1979 Ford Fairmont
[/B]
Reply #41
any codes?
Reply #42
not sure
since I swapped parts it eliminated the check engine light(egr related)
I really dont wanna swap back, because I know im not the only one running a explorer TB so its got to be something else... Its a BRAND NEW IAC as well, and i have another brand new one in a box...
car runs GREAT, and has NICE top end power, and spins off the line(never did when I bought it). Its just this stupid idle..... How do you set the TPS??
Reply #43
Swap it back just to see if it goes away
Reply #44
gah that involves a lot of work, and using a crusty old tb and egr spacer...
I got to reset the comp and a few other things and then i just might have to...
