Topic: pcv valve location (Read 5321 times) previous topic - next topic
pcv valve location
ive been going over and checking more things in my engine, and was wondering if someone could tell me where the pcv valve is located? Its not on the valve covers like i thought, any other places it could be?
FOXLESS!!
1994 Lincoln Mark VIII
pcv valve location
On a 5.0, it's in the back of the intake manifold. Kinda tricky to get to. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
pcv valve location
more towards the drivers side of the intake?
FOXLESS!!
pcv valve location
Yep big old rubber hose going to it (like 1/2" diameter or so)
pcv valve location
Here ya go. It's the black object in the center, disregaurd the arrows.
pcv valve location
Be aware that there is a wire mesh filter directly underneath the PCV valve, which can also restrict circulation due to carbon and oil deposits.
You may be able to soak it in a solvent to clean it out or opt for a new one.
pcv valve location
thanks once again for all the help
FOXLESS!!
pcv valve location
Quote from: cougarman;241020
did you drill those out to connect the rear water jackets
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
pcv valve location
Quote from: 347Thunder;241038
Sorry, not my pic, just a generic one off the net.
pcv valve location
darn I might do that
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
pcv valve location
ok what about the two smaller hoses coming off the other side of the pcv, anybody know where they run to?
FOXLESS!!
pcv valve location
One goes to the fuel pressure regulator and the other to the EGR solinend.
pcv valve location
is there anything else they could be connected to that would serve the same purpose or do they have to be connected to the pcv?
FOXLESS!!
pcv valve location
Are you talking about the pvc valve itself, does it have a big hose connector and two smaller ones,If so they usualy get plugged not used.Everything else gets hooked to the t's on the upper manifold.
pcv valve location
yea its got the larger hose connected to it and the two smaller connections have been completely removed. the pcv itself just kind of hangs down behind the upper manifold - is it supposed to be placed somewhere else?
FOXLESS!!
