Topic: pcv valve location (Read 5322 times) previous topic - next topic
pcv valve location
Should be just like the pic in post 5.
pcv valve location
mine comes off of a hose that runs out from a "T" the bottom of the intake and just hangs free, it still idles fine though, havent taken it for a drive since i bought it though
FOXLESS!!
1994 Lincoln Mark VIII
pcv valve location
Quote from: 20thanniver-ls;242330
If it's hanging it's not right.
pcv valve location
that little f tip on the pcv valve is removable (it's a generic valve) so that the 1 big hose can fit in it
pcv valve location
does the end that has the f tip have a place to go after it is removed?
FOXLESS!!
pcv valve location
um, i think this will help, i wish i toop a pic yesterday when i had the intake off
pcv valve location
Ok so its been a while since this thread has had any new posts, but it seems a waste to start a new one. I gave up on looking for the grommet that the pcv goes into for a while now, and the boredom and brokeness of my Sunday got me off my a$$ to finally start looking once again. Took me all of about 1 minute to locate it this time ( regardless of the pics in this thread i was still looking in the wrong spot). Well now the car is idling worse than it was when the pcv was just hanging freely off that 1/2 inch hose, however has no more hesitation when i give it some juice. Is it possible that the screen below the grommet is clogged with deposits? By the way the pcv itself is new. Sorry for the long post guys, any advice?
FOXLESS!!
pcv valve location
Well ive takenb a look at the screen and it is totally clogged, its so badc that you can barely see the mesh but i cant get it out, anybody know how to get it out?
FOXLESS!!
pcv valve location
The best method is to hook the mesh using a dental pick (or comparable tool) and pull it straight up.
pcv valve location
Yea thats sorta what i did, i used a pair of needlenose and pulled it out, it was filthy, i blew in it hard as i could (while getting grease all over my mouth) and it didnt let a bit of air through. Could that being clogged and the pcv not being connected to the grommet cause an odd idle and hesitation? i havent taken it for a drive yet, but it seems to be a hell of a lot better, although i fear my other vacuum lines may be in need of a serious cleaning.
FOXLESS!!
pcv valve location
Anyone know what kind of problems the filter being clogged would cause?
FOXLESS!!
pcv valve location
Quote from: 20thanniver-ls;247587
You mean the pcv filter?    The crankcase gases will build up, rob some power and find other creative ways to escape.
Sounds like you need to go over the vacuum system on the car thoroughly and see what the deal is...
pcv valve location
Well ive seen a giant increase in power and throttle response when the car is parked (currently not street worthy, rusted brake lines:mad: ) no more hesitation and screwed up idling, it dosent stall out when i hit the gas like it did before, but you guys are right, i need to thoroughly go over my vacuum lines and pull some codes, how does the sea foam thing workwhen cleaning the lines?
FOXLESS!!
pcv valve location
BTW, anyone know the proper name gor the filter?
FOXLESS!!
