Topic: New Turbo Question... (Read 1547 times) previous topic - next topic
With the old one confirmed to be dead, it's time to pick up a new turbo.  I was looking at T3/T04E Garrett's around the intraweb, is this a good route to go on stock injectors?  I'd still run around 18psi, but I've always heard people say "Be careful you don't melt a piston."
http://cheapturbo.stores.yahoo.net/gat360trw63a.html
P.S. Why are T3/T04E's cheaper than T3's?  I always thought they were an upgrade...
well i cant say why t3/t4 hybrid is cheaper than the t3... but i will say the comment regarding melting pistons has more to do with using cast/hypereurectic (sp) pistons.  also another thought is bigger turbo more airflow would mean more combustion chamber pressure and possible detonation if it isnt tuned right
Picked up a AiResearch T3/T4 today for $200 cash.  It's a .60/.63 with a new center.  Absolutely no play.  BUT, one of the fins is oh-so-slightly bent, and it just barely rubs against the compressor housing.  Do I need to replace the compressor wheel or can I gently sand the fin down so that it doesn't rub anymore?  About .5mm and it won't rub.
You'll need to get it rebalanced if you keep that wheel.  It might be cheaper in the long run to get a replacement, depending on what's what in your area.  Is there a reputable turbo dealer near you?
__________________
Twin '85 TCs
White/ Grey 2-tone
Not sure...  I still have the wheel from my T3 though.  If I swapped that over would I have to get it rebalanced as well?
Quote from: tc²;240839
No...  Each wheel is balanced seperately.  Swapping the wheel would be OK.
However, you should check the shaft diameter between the two.  Sometimes they are different.
I think I might've gotten owned...
Is the T4 housing not physically bigger than the T3 housing?  My T3 housing fits onto this "T3/T4" turbo, suspiciously.
Old vs. New
Looks that way.  Sucks.
No wonder it was only $200.
Atleast I have the right compressor wheel now...
I thought that the wheel size is related to the clearance in the housing, not the overall size of the housing, the size of the housing is more of the A.R. ratio. With all that being said, look at the housing on a stock IHI as opposed to a stock Garrett, the IHI is about half the size and they are both T-3 . I have a friend that just bought a wheel and then had his compressor housing machined. Is it possible on yours or are the wheels the same size?
that comp housing is from a garret t3 super 60 series turbo from a merkur/ turbocoupe w/o intercooler.  you got jacked.  a t3/t4 is only a t3 turbine housing with a t4 comp wheel and housing.
86 t-bird 226k miles and blown transmission
