Topic: Hoods that don't match header panel (Read 2414 times) previous topic - next topic
I've seen this on a few cars, including mine and I'm really not sure what causes it.  Is this normal on these cars or are the stops maybe moving from vibration and causing the hood to get deformed after multiple open/closes?
Here's a pic that makes it really visible (sorry if this is your car!):
1988 Thunderbird Turbo Coupe
I dunno what causes it, but I CAN say that both my stock hood, and the certa-fit "TC" hood both look(ed) like that...
it's a small pic, but look in my sig at mine...it's shiznitty, but it's not a Ford TC hood, so :punchballs::hick:
There are multiple adjustments for that sort of thing. The hood stops on the radiator core support can be adjusted up or down. In theory. They were difficult to move when the cars were new; as time progresses they're  near impossible to move at all. Nonetheless it is an adjustment. Vise-Grips and WD-40 recommended. ;)
Also, the way that the hood bolts to the hinges is another adjustment at the back of the hood. Owners of cars with factory spring-loaded hood hinges have additional bump-stops on the hinges.
there is also another large adjustment: hood-to-fender. Loosening the fender bolts and moving the panel can yield tighter gaps along the side of the hood.
Don't forget about the alignment of the hood to the header panel. The main hood latch can be moved up or down also, although you have to be very careful when you do that. But that is an adjustment at the front of the hood.
Yup is it mostly in those adjustments. I takes times but you can get if if you work at it. The hardest part is lining everything back up to line up right!
Well, if you look at the pic, you can see the hood is actually angled different than the header panel.  It's not so much that it's out of adjustment.  I'm more wondering about how the hood gets deformed in the first place.
You sure the battery not hittin it?If not its all ajustable.
the fender may be out of alignment too on that one side.
the hood looks lower all the way along the fender.
or the hood is to low on the pass side.
the front will form to whatever it's bolted down to, to a point.
It can all be fixed to look perfect. just a lot of adjusting.
and if that doesn't work. toss a 2x4 under 1 side and warp the hood to match. LOL ..J/K
Quote from: daminc;232089
J/K nothing, I've done it :hick:
I think these cars came factory with shiznitty hood fitment. I definitely see more with poor fitment than I do with good fitment. I was determined to make my TC hood fit my car, and after several hours of fussing I think it came out OK, considering I don't know what the hell I'm doing (the shadows in the pic make it look worse than it actually is):
I've done it to.
........and doors
Yeah, I haven't used 2X4's on doors, but I've used my knee. First generation Saturns had a problem with water leaks - water would get between the door and the rubber and drip on your knee. GM issued a TSB on how to repair the problem: Open the door, place your knee against the inner panel, grab the window frame, and pull. Literally, we were to bend the door so that the window frame part seated tighter against the rubber. The best part of the TSB was the statement "Although this is a proper and legitimate repair it is recommended that the technician perform this procedure out of view of customers". It would be kinda hard to explain, I guess...
kitzdnm, that's not my car; but if it was, no, because the battery wouldn't be in the front.  :D  And besides that, that hood actually has gaps that get progressively larger on each side.  If you raise or lower one side to make it better the other side would get worse.
Anyway, guess I was just curious why I see so many cars with mis-shapen hoods (not mis-aligned which was a problem I already understood)
It might be just a bad overall panel alignment.
my doors were misaligned from the factory, until last month when I replaced them.
could be a replacement hood.
I also noticed some differences between the bird and cougar quarters.. could be bad stamping.
body lines on the bird are a lot crisper then the ones on my cougar.
just things I have noticed in rebuilding my car.
I don't think quality control was at the top of the list, depending on where the cars came from. there were also interior panels that weren't welded from the factory on my car
huh, that's interesting.  It's amazing how far all the automotive tooling and what not has come since our cars were built.  Guess it's up to us to fix that as much as we can!  :D
And don't forget all the twisting and flexing the car has done in the last 20 years. somethings got to not line up after that many years
Oh yeah!  LOL so that's why my passenger door is low and sticks out 1/2" on the bottom (toward the back side if it)?
