Topic: Hoods that don't match header panel (Read 2420 times) previous topic - next topic
Quote from: booksix;232128
Oh yeah!  LOL so that's why my passenger door is low and sticks out 1/2" on the bottom (toward the back side if it)?
Mabe you need to use the 2x4 LOL
I actually started a while back but never finished!  Eastwood also sells a tool made just for doing this on doors...  after I inspect the door for rust I'll either buy the tool or a new door!
1988 Thunderbird Turbo Coupe
Found it!  They even mention the wonderful 2x4  :D
http://www.eastwoodco.com/jump.jsp?itemID=10412&itemType=PRODUCT
the door aligning tool?
I was looking at that before I put the doors on.
I have plenty of 2x4s LOL
yup, i think I posted the link while you were typiing, look above...  guess you've seen it already, but it looks cool
get the gap gauge too
I adjusted my header up in the center - it can be adjusted up and will flex a bit!
I've adjusted the center latch lower & side adjusters up to further help fix a situation like shown in the O/P. The hood will also flex a bit.
There are also many adjustments to the hinges that effect not just the rear of the hood as mentioned previously.
You can re-shim the fender if you need to raise or lower it in places for best alignment with the edge of the hood.
I had tons of shims on the pass. side of my car. none on the other
I have that too. I just passed mine off as a tweaked hood. It will make me feel better when I cut it up (has a bent corner anyways). I'm sure my whold front is all out of line. When I replaced my fender I just made it close with the door as possible and went off that. The Front of my car has been in 2 accidents ( header panel& Bumper, Fender) so Im sure its knocked out.
After I filed down my A/C bracket it closed much better but not when I get on it around a turn it pushes the scoop up and it cracked it already.
Im just waiting for the repaint and Ill get it all flush then.
