Topic: Cam ? (Read 4458 times) previous topic - next topic
Cam ?
As you all know, I'm rebuilding my car.
I'm also swapping the 3.8 for a 5.0.
I'm currently collecting parts for a HO upgrade and my question is....
what type of cam to get?
where to get one?
and, how do I know what kind to get?
This isn't going to be a race car. but it's not going to be a DD either
any help would be appreciated as I know almost nothing about building a motor.
Thanks,
Jerry
Cam ?
honestly if your doing a stock HO motor than just stick with the stock HO cam. You would be better off spending the money on a nice set of headers,catback exhaust, or 373's
I really wouldn't do an HO personally. If I was you I would be looking into a nice explorer longblock with explorer gt-40 intake and gt-40p heads and pick out a nice cam to bring it all together.
Cam ?
Quote from: Bob;229418
+1
works very well, I got a 80k mile explorer long block at the J/Y with intake throttle body fuel injectors and even ex. manifolds for $450.
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
Cam ?
Honestly if you want a whole new motor go here  http://www.fordstrokers.com/
But as far as cams go E303 sound great but i must say avoid it and Get a Trick Flow Stage 1 cam my neighbor has it in his 331 fox body stang makes 380RWHP its a nice fast car but still can be a Daily Drive except its got to much money in it so he drives it very little.
Cam ?
I am looking to put gt-40 heads on it no matter what. and working up to the explorer intake. (if that makes sense).
I still have a lot of work ahead before I even pull the 3.8 out.
I also would like some opinions of which way to go.
Right now I have
standard 5.0  in my parts bird
HO intake and injectors
I don't want to get to much stuff I can't use, If I can go in a better direction. But I also would like to use the parts I have, or at least the motor
Cam ?
Is this car gonna be a 5 speed or auto?
Cam ?
Quote from: V8Demon;229455
The bird has a C-6  that i'm planning on using, along with the drive shaft
Cam ?
Depending on how much more cam you want; an aftermarket torque converter would greatly benefit.  It's extra cost you'll wanna think about.....
Cam ?
I have the gt40 irons and the TFS-1 cam, very happy.
As for the e303 cam don’t have any experience w/it but I heard if your thinking of it-don’t its old tech plenty of reads at corral over the e303 guys are giving them away there.
Actually now that I think about it I now guy who bought a create motor from ford w/alm heads and e303 cam and he wasn’t happy till he swapped the cam to a comp cam he said it was night and day.
Cam ?
Trickflow stage on for sure,hands down the best entry level cam.
Should work well for what you plan as well.
Question though and i've been wondering this for a while??,how are you going to use a c6 behind your 302(big block bellhousing) and why would you downgrade to a 3 speed????
Cam ?
If you flycut the so pistons,you will have lots of options.
With your talent it would be a breeze!
Cam ?
He has a small block c6,its in a parts car he has bolted to a 302.
Cam ?
dont worry
hes gonna be using gt40 heads and intake ;)
Cam ?
If you are going to bolt the h/c/i onto the 302 from your parts car then I would suggest rebuilding the bottom end first. Also if you are using the auto make sure with what ever cam you go with that you get a converter to match. I should have when I did mine :flame:
If you're not going to be racing the car then I would just stick a HO cam in it or something that is similar. For the street you want low end torque. It'll be much more fun that way ;)
Cam ?
Leave to stock cam and have twice the torque at 1500 rpm's and throw the rest of the h.o. stuff in except computer and get a adj. fpr.
