Topic: long tube Headers (Read 3201 times) previous topic - next topic
long tube Headers
hey guys,
does anyone know if mustang long tube headerswill fit on a 87 cougar xr7.
Re: long tube Headers
Heddman actually makes long tube headers for the 83-88 Tbird/Cougar 5.0. :D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
here you go
but you need to put a mini starter if you ever plan to get the starter back out when you need to
stupid california smog.... :mad:
i got mac's and they fit like a dream actualy. i was surprised because everyone says what a bitch it is to install LT's
which headers are those Blown? and X-Pipe? tanks.
have to watch out that the long tubes u get do fit right,
The BBK longs will not clear if u have a AOD.
Is that oil all over the underside of your car?
Quote from: darkthunder
cheapo flow junk headers "flow tech"
the X pipe is custom made the X section is 3"
Quote from: lowcat
yep well it's tranny fluid from my old T5 it used to leak from the tail shaft before it :barf:
no more oil leaks .. those pictures where taken in September of 2003
the only thing that leaks these days are those junk headers from all the slip s they have :disappoin
doh. guess i'll buy some MAC longtubes then. Flowtechs were on my list. tanks for the info.
lol the only reason i bought them was because they where only $110.00 VS everyone elses 250+.. i'd say they are ok for what i payed for them and will have to buy another set unless i want to revamp my whole exhaust system again..  but they are just a pain in the BA!!S to install and they use slip s for most of the tubes but thats because the headers are equal length long tubes :shakehead
Nick
I had bought a set of Flowtech unequal length shorties and they were junk. You couldn't even get the header bolts through some of the holes due to the way the tubes were bent, they blocked the holes.
I did really like the Heddman Headers I bought after I returned the Flowtechs.
Any 351 owners with long tubes? Was curious about fitment with those. :dunno:
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Quote from: Warbird9
I have yet to found a set that fit right.
I wanted the BBK longs for my car i had to settle for Mac 351W shorties into a fox
i know mercoug302 had BBK's, but he had to clearance one of the primaries for the steering shaft a few times
