Topic: long tube Headers (Read 3202 times) previous topic - next topic
Re: long tube Headers
and was it a AOD car or a stick?
When i wanted the longs i had 351 with AOD.
Soon as i have my T bird done i will look into a 460 88 mark 7
I have the hedman set on my car, they fit great, Ijust had to remove the starter and steering shaft to get them in.
It's a good idea to change to the pmgr starter if you use these.
BTW these will not fit on aod or c-4 equipped cars, only t-5 or tremec or other manual
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
I was planning on a stroked 351, with a Tremmec. I was kinda thinking that the aod would be a problem with the TV and shift cables and brackets getting in the way.
By the way, sorry wayfastwhitey87 for hi-jackin your  thread.  :sorry:
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
