Topic: HELP!.... Pics inside: (Read 2330 times) previous topic - next topic
Got the pan off of the capris engine just now, and am not liking what I found..  here are the pics:
What the hell are these little broken round parts?...  :toilet:  there is no visible damage to anywheres in the motor that I can see..
your oil pump went boom!
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
from the outside, the oil pump, looks brand new...  (it is... WAS)
Appears the "junk" got into the pump and locked it up, twisting and breaking the drive shaft... I've seen similar looking lash caps(fit over the valve stem), but I don't think that's what those are...
The little flat "arced" pieces look almost like piston rings... OUCH!!!
Move each piston to TDC and inspect the cylinder walls...
What happened? Did it start making noises or did you just open it up for fun?
im guessing with the pump shaft a twisler it prob had no oil pressure
No those aren't piston rings,to thick and not the right arc.
Looks like all parts of the oil pump.take the pump apart and see what she looks like.
this just makes me double sure that im buying the larger shaft
Quote from: daboss351;221333
Why?  Like it is going to help you when your pump picks up something like mine did....
trust me I would rather be driving the car then tearing it apart for something to do... THIS is WHY I tore it arpart to begin with....  Was on the road course, downgeared in to 3rd, heard a "SNAP", lost oil pressure, pulled into the pits and shut it down.. (was just outside of the pits)
I tore the oil pump apart and all looks fine in there...  besides...  how would those big chunks get back into the pan if they grenaded inside the pump?
here is a better pic of the pieces that concern me...
the twisted pretzel of a shaft doesnt concern me, I need to know what thos things are....  The motor ran fine up to and even after the oil pump seized, so I have no clue what they are..
Quote from: 1WLD BRD;221317
...expensive... if you put them in the gas tank they will find their way home.
so the pump looks fine inside?? no sign of what locked it up??
theres only so much those parts could be
start ripping into it and find out...
Quote from: 1WLD BRD;221341
Good call, they can't unless the pump was busted...
Inspect the rockers, maybe those cap looking pieces are part pf the retainer that holds the roller pin...
Hey at this point it's as good a guess as any, and not hard to check...
Quote from: TurboCoupe50;221347
thats what i was thinking something valve train related
wide peices valve springs?
round peices part of rockers?
That's what my oil pump shaft looked like in the first '88 Bird that I had...although I had no big debris in the pan...when I took the pump apart it looked fine...it's worth upgrading to an aftermarket oil pump shaft...how much more will it cost?...2...maybe 3 dollars more than a stock replacement.  Under 20 bucks for just about any aftermarket drive.  Otherwise you're just... :punchballs:
Good luck,
Don
ok guys, I just went and talked to a buddy of mine that has been playing with these things for years, he gave me an idea where to look:
Only problem is, they are all there...  which makes me think, someone over reved it at somepoint, hit valve float and wrecked the heads, so they upgraded to these ported ones and didnt think to check the pan for any more debris....
Looks like I may be safe to throw it back together...
