Topic: build sheet ? (Read 5302 times) previous topic - next topic
build sheet ?
for all you guys that take your cars apart, where did you find
your build sheet?the one for the capri was under the carpet.ive had the back seat out of the cougar and searched under the carpet
and had the frt seats out.nada .havent taken the trunk apart yet.
so--where was yours?--irv
build sheet ?
Mine was under the passenger seat, all messed up from the seat springs. I've heard of them being behind the inner quarter panel trim in the back seat area as well...
build sheet ?
I never did find one in the silver car...and I've had it ALL apart.
build sheet ?
-the one on my low mile 'bird was laying ON the passenger seat.
build sheet ?
I found the one in my lincoln under the rear seat bottom stuck up in under the metal things under there...
:ford::oldcougar::mercury:
build sheet ?
Mine was under the passenger seat.
build sheet ?
I've found two and both were in the rear left side panel... One was partially exposed so was a easy find...
They are apt to be about any place... Many of the larger components have a sheet on it for the vehicle it's destined to be installed... Mostly they are torn off and just trashed, but a few(especially in seat springs) remain with the car and probably will stay in place for the life of the car...
Having kept registry info for the 428 Cobra Jet Torinos I found in '68-'69 they were usually n the same place but varied by assembly plant(BTW ALL Cougs & Birds were built in Lorain)... The Atlanta cars usually had one in the back seat spring(often bottom and back)... The Lorain cars had one usually under the carpet, and Kansas City cars usually had one in the front seat springs...
build sheet ?
Pass. seat on mine
build sheet ?
Out of the 3 cars, I've never found any of mine.
And I've completely taken out the interiors from all 3, too.
build sheet ?
Sometimes on older cars (1960s-70s) the build sheet was placed on the top side of the gas tank. That's where it was on my brother's 1973 Trans Am. Now I've never heard of one being in that spot on our cars but it's another possible location. Otherwise it's also possible that it's under the carpeting somewhere. But in most instances the build sheet for these cars has been either on the underside of the passenger seat or behind the rear interior panel.
build sheet ?
Quote from: EricCoolCats;217833
Common location for a GM, yet to see any Ford product with one on top of the tank...
build sheet ?
Quote from: FordTruckFreeek;217778
x2
never seen one
my old 70 torino's was under the rear seat springs
build sheet ?
My blue 88 was under the pass. seat, well most of it was lol. The 87 only had about 1/8 of it left.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
build sheet ?
My 86 XR7 had it on top of the gas tank.
build sheet ?
I found both of mine, the 1988 and the 1987 under the passenger seat springs. They were both trashed, I waqs hoping to scan them into the computer to reprouce, but now some pieces are missing. Anyone have a build sheet in good condition they could scan into the comp?
john
