Topic: show me your SFCs and ChuckW crossbraces (Read 6016 times) previous topic - next topic
Anybody installed them?  Anybody taken pics?  Thanks.
__________________
Twin '85 TCs
White/ Grey 2-tone
Here is a pic I took over the weekend with the prototype SFC's with the braces I installed oh....10 years ago...
The main tubes on this car are only 4' long, but you can use about 5' really. (I was limited at the time by what the boss wanted to do).  It doesn't matter now that they are tied into the jacking rails and the cage.
At the back I always angled the end so it would extend over the drop in the rear SF to get more weld area.  The SF doesn't dip down like this on Mustangs.
Hell, I don't think I ever took any pictures of mine after I installed them.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Car's at the shop for final suspension work and the suspension will be finished (yaright).  The welder would like some more info on the SFCs.
Chuck, does yours have the small flat and z-plates?  Can you take a pic from the side to better show the cross braces?  TIA
Red_LX, get on it!:D
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: t3skidoo;216342
Do what to who?  What plates are you talking about?
They aren't that difficult honestly.  The crossbars are stamped "D" and "P" and they bolt up under the seat studs with the cutout at the front. The studs will most likley need to be replaced with bolts as the studs are short.  8mm and 12mm are the bolt sizes, both need to be about 40mm long.  You may need a spacer between the crossbar and the floor on the 8mm bolt ( The lip on the reinforcement plate for the bolt is taller than the threaded boss in the floorpan, you'll see it when the crossbar is put in place).
The main tubes are just about 5' long pieces of 2" wide steel that run from front to back, no bends or offsets.
Put the crossbars under the seat studs, put the main tube in place and line it up like you want it.  Tack the crossbars in place and then take them down for welding.  Coat them the SFC's at this point if you desire.  Put whole assy back up under car and weld in place (after prepping areas to weld).
You can add side plate on the subframes if you like, or not.
Not sure what info this guy needs, it's not rocket science honestly.
Hmmm, I have the MM full-length for a Mustang (some dope at MM told me they would fit as shipped) but I had to bash them with a full sledge hammer 'till they were nearly straight (which made me feel like an idiot when I realized that straight rectangular tubing was all that was needed). It looks like I may be able to slide the cross-braces in the gap between where they are welded to the torque-boxes and the floorpan. Then again, I welded the tubes to anything and everything so I may not be able to slide them into place - I need to check. I noticed in the other thread that you still had some left...
Quote from: Cougar5.0;216347
Which makes me wonder why MM doesn't make full length SFCs for our cars...
Quote from: JeremyB;216350
Because...
The only reason KB did them was because I did all the work and said.. "Hey, here's a product we could sell some of".  They actually cost less than the Mustang one's to make....and they insisted on charging more.
I didn't weld them in yet. I still need to seam seal and finish coat the floor before I install them for good.
If you look hard you can see them in there.
Had to put it on a angle, because of the floor being angled.
Quote from: daminc;216376
That's the way they are supposed to be, angled.  If you notice (on an unmodded set) the height of the front of the brace (above the notch) is about 1/2" more than the rear of the brace.
Quote from: Chuck W;216378
Then I guess I did it right. I was starting to worry that something was bent. seeing I had to build a lot of the floor on that side, I don't know what it really should look like. I wish I had something to copy when I made that side.
The guy knows cars but not so familiar with Foxes.  I think the big issues are the side plates and cross braces.
I was hoping for some pics like this but better detail
http://memimage.cardomain.net/member_images/10/web/478000-478999/watermark_478078_364_full.jpg
I got the SFCs a while back on TF and the instructions are .. minimalist.    To make matters worse, I dropped off the car and wasn't able to actually walk him through what's what.  He's just got a pile of parts sitting next to his welder and lift.
Chuck, thanks for mentioning the angle.  I didn't know that about that either.
Thanks for all the pics.
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: daminc;216381
Those are some nice looking braces you made there....  You will notice a difference for certain.
That should car should handle realy nice with all that stuff looks good.
Quote from: Chuck W;216401
Thanks,
As long as I'm rebuilding the car, should I use the CC plates coming up? also, I'm also thinking of making tower braces for the front end.
And motor mounts, when the next batch happens
