Topic: show me your SFCs and ChuckW crossbraces (Read 6005 times) previous topic - next topic
Well the CC plates are still uncertain on a timetable at the moment.  Kind of buried under a bunch of stuff.
LOL, Thats ok for me. I don't know when I'm tearing apart the front end. I have to make a back end first.
back from the shop
Battery and parking brake cables not secured yet.  The welder sprayed black to protect the welds.
__________________
Twin '85 TCs
White/ Grey 2-tone
more
__________________
Twin '85 TCs
White/ Grey 2-tone
more
__________________
Twin '85 TCs
White/ Grey 2-tone
how far into the front channel do those run? i dont see any plug welds thru the channel
If I remember correctly, there's an anti-crush sleeve about 10" in.
Thats why I cut the frame bottom off and notched the SF another 10" on the bottom of the frame. I made mine almost a full 5' long
welded inside the frame from inside the car and outside the full length of the frame. plus welded the floor to the frame.
Quote from: gumby;224954
Hmm, good question, maybe 2-3 inches into the front sub?  I stuck a coathanger wire in there to try to feel for the front end of the connector, no way I can see for sure w/out drilling.
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: t3skidoo;224963
do you remember how long they were?
t3skidoo-
Why did you have to chop up the crossbraces?  Oh wait....you have them installed backwards...
I see what the deal is now.  You put the front part of the SFC into the front subframe instead of below it.  To be honest, you might have been better off to cut the crossbrace in two and mate it up/weld it to the sides of the main tubes.
Quote from: Chuck W;224967
t3skidoo-
At one point he asked about notching the cross braces so they'd fit, but I don't know if he did.
Of course, the purpose of this thread in the first place was to avoid having to undo everything with a cut-off wheel and a cutting torch.:flame:
__________________
Twin '85 TCs
White/ Grey 2-tone
I explained how the crossbars were "supposed" to be installed.  However, with the recessed or "unique" installations, there are some tweaks that need to be made.
If you had these installed for you, the guy didn't really serve you well with the install.
Quote from: daminc;224966
Not accurately enough to measure the unseen part.
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: Chuck W;225019
yeah, that's possible.  question is, what to do at this point?  leave it, s it, modify it?
__________________
Twin '85 TCs
White/ Grey 2-tone
I say go for the gold, jacking rails and cross-braces
