Topic: 1988 Two Tone Cougar XR7 VORTECH V-1 NEW pics page 25 go look (Read 47563 times) previous topic - next topic
Reply #90
Birdman i will ask for you all i know is its like a little over $200 or so but it looks good.
I get in toruble for posting to much but when i get more pics i will let you guys know.
Reply #91
Quote from: Birdman;231222
Hey!
Is that the Proliance aluminum core/plastic end tanks radiator?
If so, How is the fit and finish?  I'm considering buying one for the t-bird.  It looks to be a 1 row, right?
I put this on my car in 30 minutes and works very well. The dirver's side tank looks not quite straight but not very noticable in the car. Very easy install and looks good. Dropped my coolant temp 30 degrees or so.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=200238955111&ssPageName=STRK:MEWN:IT&ih=010
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
Reply #92
New pictures much work has been done and the engine sounds nice video clip soon.
P.S thanks vinne for the wiring you saved the Cougar Project A+
Reply #93
Wheels look good
Reply #94
a few more shots
Reply #95
last 2
Reply #96
sweet...looks like you might need an intake spacer. is the intake touching the valve cover? id probably go with wider tires as well. the ones on there look a little skinny.
~John~
Reply #97
I got a intake 1" spacer does not fit under the hood so its for Sale make a offer if anyone needs it the tires and wide enough and Nitto Street Slicks cost way 2 much for a set anyway the tires stay till i make them go away by burning rubber.
Sliver and Blue paint job soon with a few blackouts and custom embelms on the whole outside.
Reply #98
Is that going to be enough fan?
Reply #99
Try a half inch spacer.It looks like you really need one.Maybe a second gasket between the upper and lower.You're welcome about the harness.Leave me feedback.
Reply #100
I kinda like the wheels on there...that PCV valve looks pretty angry...you know they sell 3/8" spacers for most intakes.
good luck,
Don
Reply #101
Looks good. I agree with the tires. Dished would have looked sick on the rear. Paint? Who needs that? Primer and and speed is all you need.
Reply #102
Quote from: Carpimp1987;231214
How do i post more than 3 pictures at a time?
Get a free hosting service (like Photobucket, there are a few people around here that use it), upload all your pictures there, and when you are typing your post, there is a button you can click that allows you to enter the web address of an image, which is then shown in your post.
1. Upload your images to photobucket.
2. Type your post, and use the "Insert Image" button:
3. Enter URL (web address)
For example, I entered http://www.cougarxls.com/pf/enterurl.jpg.
4. Image will appear in your post if you've typed the address properly.  Some sites are case sensitive.
You can add as many pictures as you like in a post at once (just don't forget those dialup people :hick: *Edit: LOL, and those of us who never really cared for your paint schemes :poke: ).
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
Reply #103
Cougar XLS thanks i will try that next round of pics.
most of the bodywork is done and the window trim is taped off
tc scoops and mirrors will be black
top and bottom of car blue
middle of car sliver
inside trim Ford Porn red and NAPA red
Reply #104
great, thanks alot CougarXLS.....
*sniff sniff...*  I smell rice.....
