Topic: drive shafts options (Read 1934 times) previous topic - next topic
http://www.pstds.com/custom_driveshafts.htm
from that website, im thinking about getting the Street - Strip Aluminum Driveshaft or the Chromoly Driveshaft. does anybody know anything about them? if they are even worth the money?
i think i read something about you can get an aluminum driveshaft from an aerostar van just use your yolk and it bolts in... but as far as the price and being worth it i cannot say
at the pick n pull here you can get an aerostar drive shaft for 10 bucks!
:pics-stfu:
 Project Thread with pics
I thought the Aerostar drive shafts were a swap for the stangs.I don't remember them fitting our cars.I hope I'm wrong.If I am,I can grab those all day long.
if i remembered where i saw the info id double check for yall.... but im a male and suffer severly from short term memory loss....
Well i have always gone over kill in my driveshafts.
If you are making any good power using slicks now and then or drag radials just get a shaft made.  Stock shaft with good Yoke and U joints are OK for mild cars.
Quote from: the_intimidator03;212337
I also suffer from memory loss,but I can't remember when it started.
What?? Who???
well, how long is my driveshaft? from where to where do i measure it?
Getting a shaft that's too short and having it stretched isn't going to save you money.  A decent aftermarket Al performance DS will run you $400-500.  A carbon fiber shaft isn't necessary for our cars.
One inexpensive option is to get an Al shaft from a Crown Vic, have it shortened to fit.  Another inexpensive option is to have the dampener removed from the factory shaft, then have it rebalanced.
Take the junkyard shaft and yours to the driveshaft shop, they can do the rest.
__________________
Twin '85 TCs
White/ Grey 2-tone
how long is my drive shaft?
Quote from: quicksilver;212574
measure it
1979 Ford Fairmont
[/B]
Quote from: quicksilver;212526
center of u-joint to center of other u-joint
1979 Ford Fairmont
[/B]
ok, thanks for your helP!
