Topic: 408 stroker project (Sold 4/2020) (Read 141568 times) previous topic - next topic
408 stroker project (For Sale 5/2018)
Reply #60
SMOKESHOW! really nice cat.....
[/IMG]
Just enjoyin the ride!!!!
Reply #61
Hey Bob, it looks great!  The rest of the work has to feel like it's manageable now.  Planning on CatJam next year?
Reply #62
Quote from: 86T-bird;236552
Yeah I should be at CJ next year, might not have it painted by than but it will be running good.
heres a couple more pics. Now I just need brakes, suspension, install rear,wire the starter, 3G alt, fan, neutral safety switch, radio, alarm, figure out how to close the hood :hick:
Reply #63
Almost there! Whats going on with the heater core hose? I have never seen one like that before but that means nothing
Reply #64
Quote from: cougar86_89;236608
you mean with the electronic piece on it? I think its so the heat doesn't run till the coolant is warm so it doesn't blow cold air.
Reply #65
Is it alive yet?
Reply #66
Temp sensor for the EATC...
Quote from: Bob;236576
Now I need tofigure out how to close the hood :hick:
That's easy, just climb on the hood and...
BTW, she's lookin' GOOD...
Reply #67
any new progress... looking good I always liked trickflow valve covers
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #68
Looking good :D
I see you've done the distributor mod ;)
Reply #69
Looking good. Remember if yours gets done first, you owe me that ride.
Jim
Reply #70
Quote from: thundr306;238191
Jim
Speaking of which... hows that going? Do they have it now?
Reply #71
Thanks for the kind words.... I do have some progress this is one of those things you take one step forward and than two steps back. I knew it wasn't going to be easy. I am moving forward though its just been a slow process.
I've been dealing with lots of issues with the wiring harness under the hood. The previous owner was a firm believer of "twist and tape" for all his connections and that works in a jam as a quickie but after time (2-3 years) the tape falls off and all you have is bare wire waiting to hit a ground somewhere.
I've been soldering and shrink wrapping wire everywhere under the hood and under the car. I had to completely re-wire the WOT A/C relay because the wires were left next to the header un-protected from the heat and were all melted and burt.
Also I just noticed my engine that has never ran yet has developed an oil leak. Not at the gasket but on the pan at the front sump it looks it took a hit on the last setup and a py repair attempt of some shiznit was used to try and seal it up.
Last is the hood that will not close. I tried Tom's advice and jumping on it didn't help. I'm going to have to bite the bullet and buy a hood for it.
My next update should be of the engine running , I got my fingers crossed :)
Reply #72
Quote from: DVP;238192
Not yet, I delayed it for a little...check my post soon.
Bob, that looks real nice. A/C too, huh? I like that.
Reply #73
couple more
Reply #74
That's looking real nice.
Why didn't you just get another harness, instead of all the repairing?
