Topic: i got a little creative yesterday. (Read 2899 times) previous topic - next topic
after putting the motor back in the turbocoupe, i decided to fab up an egr block off plate.
87 thunderbird turbocoupe
06 pontiac g6 gt
:birdsmily:
Nice.I'm about to make one for my 5.0.I just need to get some aluminum.The piece I have is about 1/8 inch thick.I need it a little more sturdy than that.Yours looks great,like you bought it that way.
Quote from: vinnietbird;210509
thanks.  this one is 1/4".  i think it'll hold up just fine.
06 pontiac g6 gt
:birdsmily:
I'm going to the syard tomorrow and grab some of that aluminum.You've inspired me.
Lookin' Good!  What all did you do with the 2.3 when you had it out?
Quote from: tc²;210554
high flow melling oil pump, new seals/gaskets throughout, swapped on an svo cam cover (i just think they look better.), and a kirban fpr.  i was going to swap on a 65mm tb, but i need to either make an adapter for it or buy the kit to put it on.
by the way, i've got another question for you... i'll send it in a pm.
06 pontiac g6 gt
:birdsmily:
Is there any performance benefits to blocking off the EGR?
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
Quote from: SR71TC;210580
Nope.
I'm using 1/8" thick aluminum. Used the gasket, and some copper gasket sealant. 24psi of boost an no issue.
1/8 aluminum I have.I'll try it when my new Dremel gets here.
i just use a 351C fuel pump plate works fine!
block the egr? just say no.
Quote from: Tbird232ci;210626
Nope.
you might even see a performance drop, esp w/ gas mileage.
__________________
Twin '85 TCs
White/ Grey 2-tone
Forgive my ignorance... but why do you want to block off the EGR?  What pratical purposes does it serve?  How would the fuel computer react?
I may be out of context, but I do have a mind-dot when it comes to blocking the EGR valve like that... a couple of years back, Cougar A was having stalling problems, and the mechanic at the shop used a penny (a freakin' one cent POS) and some kind of heat/putty glue, it did fix the stalling problem, but eventually created more problems than it solved.  When I confronted the mechanic, his only response was, "I thought you where taking the car off the road, and only needed a temporary solution"
:mad:
Two some odd years later, there is still an outstanding invoice... but suffice it to say, I will never EVER let anyone touch my car EVER AGAIN. :beatyoass:
So, I am curious?  Why block off the EGR?  Is it because you've done some other mod that requires the removal?  I'd really like to learn.
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
I blocked mine off, and noticed nothing.
alright.... i know there are no performance gains from this.  the ONLY reason i did it is to clean up the engine bay a bit.  i've done this to every single one of my 2.3 turbo motors and have never had a single problem.  one of these motors has been in service for 4 years now with no ill effect.
06 pontiac g6 gt
:birdsmily:
So then really your only reason for blocking of the valve is because you can...?
