Topic: 83 t-bird (Read 2868 times) previous topic - next topic
83 t-bird
83 t-bird-351w-.030 over-flattops-paw hdy. cam-rhodes lifters-hv oil pump-crome molley push rods-oil pump rod-dual chain-69 big valve heads-ported & polished-dual springs-guide plates-cradle rockers- 7/16 studs-polley locks-elbrock alu. 360 intake.-750 holley-mustang shorty headers-duals with turbos-lincoln aod-3:43 track lock-15" mustang rims-sun roof-tinted windows-vent windows-cd player-gauages-
ums/gg277/bad-ve-6/83T-BIRD009.jpg[/IMG]
83 t-bird
i believe that is called false advertising :hick:
83 t-bird
Quote from: gumby;205136
 yes :D  i just changed the motor and not the plates ,any car guy or gal that hears it will know.just can't tell a book by its cover huh.:birdsmily:
83 t-bird
So..you changed the taillights and added the 3rd brake light?
Looks like you had your work cut out for you.
83 t-bird
Nice.
Is it a Heritage?
83 t-bird
looks really good!!
bet the 351 is muccccch more fun then the 6!
83 t-bird
WOW what a beautiful birdie! Love seein the modern TFI electronic ignition dizzy, along with an old-school carb air cleaner lol. All in Ford Blue too. Awesome.
83 t-bird
Quote from: ZondaC12;205198
Son you are confused.. That is a Duraspark Dizzy.
tail ligths
Quote from: Chuck W;205140
no 3rd brake light was factory. didn't like the 83 tail ligths so i put 86 in.
83 t-bird
Quote from: CougarSE;205161
Nice.
Is it a Heritage?
 yes it is. i think they came with vent windows and the other models didn't,is that right or not?
helps
Quote from: daboss351;205191
looks really good!!
 i detune it somewhat with a smaller cam .but it still holds it own pretty darn good. :birdsmily: i was surpized the weight didn't hurt the handling any. i did use one spring rubber spacer in the front on each side. its my toy mostly as my dd is a 88 mark 7. all on americanmuscleregistry.com  as bad-ve-6  :birdsmily:
83 t-bird
you have a mark 7 as well? my mark is gonna be my first car, then have a 351w powered 66 mustang coupe
good luck with the birdy! I love the old four eyes!
83 t-bird
Nice car.You do good work.I like all of that blue under the hood.
83 t-bird
Quote from: bad-ve-6;205214
That is what I asked...
I saw it was said to be an '83, but the rear end was '86.  Then I checked the other clues and figured that's what you did.  Not my choice, but whatever works.
83 t-bird
Quote from: CougarSE;205202
Oops! :hick:  Howd'ya know the difference? I think I see a vacuum advance unit there? That it? All I know is the casing and the cap look exactly like mine, and everyone else's 5.0's original one I would imagine.
Guess I dont know when they switched over. My cousin's '85 Grand Marquis has TFI..? *heads to coolcats*
