Topic: Torque Converters (Read 1528 times) previous topic - next topic
Torque Converters
I didn't get everything nailed down yet but it looks like I am getting a built AOD for $400 and an 8.8 axle with 3.55s and trac lock. If I get both, or just the trans, what should I go with for a converter? What would be a good choice for after I get my HO conversion done?
2004 Impala
Torque Converters
If your getting a "built" AOD It should come with the converter.
There usally matched .if not somewhere around 2000-2800 on and aod + HO,theres to many variables.
Torque Converters
Had a 22-2400 on mine when it had the stock HO.
Even used it before the trans swap with the supercharger,good stall range for a stock HO.
Torque Converters
I'm still ironing out the details so I dont know if it has a converter or not.  I never assume anything.
2004 Impala
Torque Converters
Quote from: dominator;202972
Agreed 22-2400 is a good range.
Torque Converters
Ok the story is its got a hardened input shaft, and an upgraded overdrive band, for sure.  he said the shop that rebuilt it did more and he was assured that it would handle more than the 400 crank hp he was going to make.  It has no shift kit and no converter and I have to put the right linkage rod into it for my hammer but $400 for a newly rebuilt trans with 0 miles on it sounds like a pretty good deal to me, I just need a shift kit and a converter.  Oh and the deal with my 8.8 TC rear fell through I'm pretty bummed about that.
2004 Impala
