Topic: Mid/low 13sec 5.0 project (new video and pics 7/11) (Read 249525 times) previous topic - next topic
Reply #435
I got a 3/8" spacer from Trick Flow.  There are 2 fittings on the bottom of the intake that dont *quite* clear the valve covers.  Even if it does barely clear with all the gaskets on, I'd rather have a little extra space there anyway.  Don't wanna be hiding those gorgeous valve covers!
Reply #436
Also, it's worthy to note that I managed to grab a set of 1 5/8 equal length shorty headers for dirt stinkin cheap.  Worst case I'll just sell em.  Think I should use those or my current stock shorties?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HOK-6128HKR&N=700+400390+300771+4294902386+4294925005+4294908331+4294840126+115&autoview=sku
Reply #437
looking good man!
Reply #438
Any suggestions on the headers?  See post 436
Reply #439
Quote from: kingcars;259914
If you can make them work, I would use them over stock ho's.
Reply #440
Quote from: Kitz Kat;259919
X2. Crush bends suck
Reply #441
any progress as of late kingcars?  I'm itching for some more youtube vids.  lol.
Reply #442
Quote from: 50tbrd88;260940
Got an update for ya comin right now :D
The engine is FINALLY really starting to come together.  Saturday I had really hoped to have the engine mostly together, but a horrible cheap timing chain that didnt fit kept us from making much progress.  To try to catch up on the lost progress, Dad and I spent 2 evenings degreeing the cam.  We found out it was an earlier model cam (266/266 duration) and set it to 2 degrees retard just to give it a slight bump on the top end without hurting the bottom end much.  Then today I cleaned up a few little things, spent a full HOUR prepping all of my brand new ARP head bolts with moly lube and thread sealer, torqued the heads, then installed the spider and pushrods.  Pics:
^Spent $105 on that dang timing chain...taking pics of it while I can!
I'll end the update with this:  I feel it's safe to say that we can finally start counting down the time left in WEEKS now :D .
Reply #443
Looking sharp!
I can only hope mine will look a third as good as that when I get ready to drop it in...
Reply #444
Wow 105 on the chain, which one was it? What cam/head/intake combo you going with?
Reply #445
Quote from: Bob;261316
It's a Cloyes billet 9 keyway set.  The first one I got was a Zoom 9 keyway for like $40, but the chain had tons of slack in it (enough to where you could turn 1 gear a little bit without turning the other).  I ordered the Cloyes set and it is a much better built set all around.  Fits perfectly.  As for my H/C/I combo, read the OP, n00b!  :flip:
Mod list:  GT40Y aluminum heads, stock HO cam, 1.7 rockers, Explorer intake, 9.5:1 comp, bored .030 over, forged pistons, ARP rod & head bolts, 65mm TB
Reply #446
what pushrods are they in the picture? Are the heads new or have they been cut?
sorry for not reading the other 400+ post and 44 pages lol
Reply #447
Quote from: Bob;261384
Stock pushrods, cut heads.  Have a shim kit to adjust with tomorrow.
Thats why I have all important info summarized in the OP :) .  If you look, I still keep it updated.  Just givin ya a hard time, though!
Reply #448
Quote from: kingcars;261388
You should measure the pushrod length with two adjustable pushrods  and than order the correct length pushrod than you will not need shims. Also you should be using hardened pushrods too. Just my $.02
I'll go back and look at the post thanks
Reply #449
Quote from: Bob;261390
he's not using stud mount rockers
1979 Ford Fairmont
[/B]
