Topic: 302 throttle body (Read 2938 times) previous topic - next topic
302 throttle body
Why did for put a dual throttle body on the F series and bronco's while the passanger cars got one?  The 351 got dual as well but much larger.
I am pulling the white cougs motor again here soon and the setup will look like everyones typical cookie cutter layout, nothing fancy other than megasquirt which is in transit.
later on this year, I want to transiton my hogged out lower intake to a single chamber followed by my TB and additional duct to the fender wells to the CAI.
just curious about what ford was thinking.
302 throttle body
Are you sure the TB on 351 is bigger then the 302, I always wondered but i thought i heard somewhere they were the same.
Maybe it has 2 duels for the rectangular intake opening, like the pass intake is more of a square so 1 circle would fit instead-I don’t know that’s my guess there’s probably a better answer.
I know they sell aftermarket TB for the trucks and there duel as well.
If the 351 is bigger I guess that would be a good upgrade from the boneyard.
I like this site for my bronco maybe they could help http://www.fullsizebronco.com
302 throttle body
The truck manifolds flow more air than their passenger car counterparts.  My guess is that this is part of the reason for the different TB's.
302 throttle body
Aren't the truck upper manifolds and throttle body higher up than ours?
302 throttle body
Quote from: vinnietbird;198076
yes,
they are much higher.  Infact, i believe the 351 is even higher than the 302.  I am not planning on using any of the truck intakes on the coug btw.
I have a 351 bronco 4wd 5spd and the TB is larger than the 302 truck tb's ive came across.
302 throttle body
According to this the 351 and 302 use the same TB but the intakes are totally different the 302 being square ported and the 351 being oval.
http://www.fullsizebronco.com/forum/showthread.php?t=6111&highlight=351+Throttle+body
302 throttle body
You'd need a cowl hood to fit a full, uncut truck manifold on a 5.0 in a fox passenger car.
When the EFI manifolds first came out it was not uncommon to see modified truck manifolds on Mustangs.  The runners were shortened a bit in some cases, a lot in others.
302 throttle body
I’ma still learning you guys are ages ahead of me w/this stuff.
I did realize I wouldn’t be practical to run the TB like a truck, but I now some run the lowers is it the TFS or Holly upper that bolts to the truck302 lower or was it salene or professional products. And whose mounts to the 351 lower.
302 throttle body
With all of the aftermarket throttlebodies on the market,wouldn't it be almost pointless to adapt a truck t-body?Heck,I have a 65mm sitting on my workbench collecting dust.I've seen 90mm throttlebodies for our cars.Way to much air for my engine.LOL.
302 throttle body
Quote from: jcassity;198094
yes,
hes not thinking of running a truck tb on a car. nor wonderign how it could be done.
if i understand him correctly, he wants to know why ford desided to run a dual butterfly throttle body instead of one big one.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
302 throttle body
Quote from: grutinator;198181
:bowdown: yep.
302 throttle body
The clouds have parted,the sun shines,and now I see.
302 throttle body
Quote from: vinnietbird;198261
the point you made earlier is my same point in fact.
302 throttle body
I have been enlightened.
302 throttle body
As stated above the truck manifolds flow more air.  They also have huge runners for torque.  Part throttle driveability pops into my head, but I've found nothing yet to confirm or deny this theory.
Many of Ford's cars nowadays also came with the dual TB's.  Pretty much any Cobra from '96-up, the newer 4.6 3V, the GT500, the Ford GT.....
*Edit*
Found this:  http://f150online.com/forums/showthread.php?t=307813
As per post #4 is seems someone else either has the same theory as I do about this or just knows something I don't:
Quote from: StrangeRanger from the above thread
The dual T/B and split upper intake is designed to increase intake velocity and improve volumetric efficiency at lower to medium RPMs, generally considered a virtue in a truck engine.
I guess the idea would hold true for a relatively small V8 meant to make power in the higher RPM range as well.
