Topic: 302 throttle body (Read 2936 times) previous topic - next topic
302 throttle body
Quote from: V8Demon;198373
As stated above the truck manifolds flow more air.
Wouldn't all 5.0L engines flow the same amount of air?
2.5 liters per revolution of the crank.
302 throttle body
Quote from: softtouch;198378
That's where volumetric effeciency comes into play.;)
You can get more air in and out of a motor.  With enough fuel to support it, you can make that engine have more power.  You can also set it up to have good power at differing RPM ranges.  This is why there are so many different approaches as to getting the same results.
302 throttle body
Quote from: V8Demon;198382
Yup, race engines with well tuned induction and exhaust systems, actually have more than 100% VE...
As for the dual throttle body, IF it's so great why did they go with a single TB and GT-40 intake on the 351 Lightnings??? Well I'll tell you this much... Cause 351 Truck manifolds SUCK(and I don't mean air)...With the small runners and sharp curve in the lower a good 5.8 will be choking at 4000 rpms... I gave one to the s guy a couple years ago...
302 throttle body
Less concern for towing capability?  More emphasis on E.T's?
302 throttle body
Quote from: V8Demon;198414
Sounds good to me... LOL
302 throttle body
Whew!! Tried reading-up on volumetric efficiency. I'm going to leave that to the experts.
