Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1537942 times) previous topic - next topic
Reply #975
more blasting today
Reply #976
Good time to drop in a tubular K. Buddy just got one for his drag mustang. They are crazy light.
Reply #977
Nice blastin'.
I've thought of installing a tubular K-Member,but after the 5 speed and everything else installed or removed,it raised my car like I was going off road.I'm stayin' where I am.BUT,if you're planning on it eventually,DVP is right,now's the time.
Reply #978
What kind?
What type?
My birthday is coming soon. ;)
Reply #979
Quote from: daminc;258730
What kind?
What type?
Think he went UPR. I know his control arms were UPR
Reply #980
What year swaps with my 87?
or would I have to swap everything down to the rotors?
Reply #981
Quote from: daminc;258748
There is a little work that needs to be done to make it fit. There should be some old threads around. There is one about having a run of them made for our cars that have alot of info IIRC. You sould be able to re use all your stock parts but I am not totally sure.
You will have to go to Mustang motor mount I bet.
Your motor should also sit lower. The stock Mustang K sets the motor lower from what I have heard so so should this one. Lower center of gravity, thats a plus
Reply #982
Quote from: DVP;258759
on my year it raised it 1" another reason I had to get the cowl hood
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #983
Quote from: 347Thunder;258779
Really? I am not totally sure about the whole dropping thing. It is hearsay from here though. I am going to find those old threads so I dont look so crazy
EDIT
http://www.foxtbirdcougarforums.com/showthread.php?t=18783&highlight=member.
Seems to have some good stuff and the links too.
Oh and you could go coilovers if you feel the need too!
http://www.foxtbirdcougarforums.com/showthread.php?t=862&highlight=K-Member
Here is a list of options too. Im sure prices have changed but still a good source of info.
Reply #984
Quote from: DVP;258793
EDIT
all I know is my hood closed before and after the k member it did not :D
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #985
hmmmm...
I'm thinking it's probably not worth the time and expense right now for something that I may only put 500 miles on in a year. (if that)
I'll just use the stock parts and new bolts and sleeves and stuff to put it back together. Someday if I do it, it'll make things easier for the swap. I really don't want to turn the front end into a major project. I really want to repair it to get it back together quickly. There's still a lot to do and Catjam gets closer everyday.
Reply #986
Quote from: 347Thunder;258809
I think it depends on which one you get. I could still be wrong on that though. I read that some of them even move the front wheels forward.
Reply #987
Jerry, no need now to do it. Maybe when you build the other motor for it Then yeh go for it.
Reply #988
Quote from: Kitz Kat;258833
Good idea, I didn't think of that.
Reply #989
With what you got goin on its not hard to forget where your at.
