Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1538010 times) previous topic - next topic
Reply #945
The lower A/C line disconnects right at the firewall. That big "ring" shaped thing is the connection. You need a special A/C line disconnect tool. Stick the tool into the ring to spread the spring inside it, then pull the line away. IIRC the spring is on the side facing the firewal, so you have to stick the tool in from that side.
Reply #946
Thanks, I'll se if I can borrow one
Reply #947
And if you don't have the tool, buy the plastic assortment of sizes ones from the part store.  They seem to work better than the two sided metal ones.  Snap the plastic one on, put a bigger open end wrench next to it, and give the wrench a whack with a hammer.  Should pop right in.
1987 TC
Reply #948
Quote from: Cougar8775;257840
i also touched the drivers side 1/4.
Rather than people having to drive to NY to pay homage to Project Evolution, I think Jerry should travel to our houses and share his magic touch. He could make stops across the country and "lay his hand" on our cars. "I am daminc, I command you to cast out the evil that is rust and replace it with the wholesome goodness that is shiny paint!!"
1987 Turbo Coupe - Son's car
1934 Ford - My project car
Reply #949
Quote from: daminc;257997
How did you disconnect your fuel lines? The plastic disconnect tool pack is cheap and handy to have.
Reply #950
Quote from: Kitz Kat;258092
the fuel lines had a locking tab on them. I just pulled it out to disconnect them.
where do i get this connector tool?
Reply #951
Just about any parts store.
Reply #952
And I hope you have better luck than I did... there are several differant styles out there.. Google
"A/C Line Quick Disconnect Tool"
I have tried
http://www.hermanscentral.com/product/otc-6538-4-pc-ac-line-quick-disconnect-tool-set-17532.cfm
and
http://www.mytoolstore.com/kd/kdengi04.html
3290 — Ford Air Conditioning and Fuel Line Spring Lock Coupling Tool
Here is a sweet Video showing the simple plastic ones
http://www.ehow.com/video_2327788_ford-explorer-mercury-mountaineer-disconnecting.html
Now when I had to do mine however... after 4 hours fighting All the above tools and the  thing still not coming apart... I ended up using This tool..
http://www.jamestowndistributors.com/userportal/show_product.do?pid=3627&BASE
worked great.. few secounds and it was off..
Reply #953
I went to Autozone and bought mine for $9.00.they have them just hanging on the shelf.
Reply #954
I've used the last one on the ac lines. I got a small plastic tool. It looks like a flat circle with a small raised ridge in the center around the hole. It worked really well on both ac and fuel lines. I think it may have came with the first one in your post, jim.
Reply #955
Thanks guys, I'll be getting one tomorrow.
Reply #956
Got me some of those plastic locking ring dis-connector thingys for thr ac lines......... worked great.
just clip it around the tubing.
push it into the connector.
and pull it apart.
and oh , a hole
so I decided to pull the bumper shocks off to.
What the heck. Why not. Looks like were into a full rebuild of the car anyway.
And that radiator support isn't looking very good either.
[SIZE="4"]Helloooooo.........[/SIZE]
Looks like I have to either replace, or rebuild this one.
Well I didn't do much today, but as always, I had fun.
I tried to find some spring compressors that would work on the front end, but didn't have any luck. I'm thinking about making one out of threaded rod and some steel plates to remove the front springs. I don't know it I have enough balls to lower the arm to get them out without something going through the center of the spring in case it launches. Mabe 25 years ago I would've, but not anymore.
That's all for today.
Reply #957
It looks like it was starting to buckle. I forgot you still had the front to do. Almost there. Almost to 100 pages too
Reply #958
Quote from: DVP;258288
Rad support?
Reply #959
Nice gloves,lol no wonder your hands look so pretty. I know you play the strings. Do you want my spring comp. send it back when your done with it.
